Brakes won't bleed up !!
  clio 182
Ok i changed my calipers, and therefore i had to bleed my brakes,
I started with back, and worked to the front.
The brake pedal goes stiff, once i start the engine it totally goes to nothing the brake pedal goes to the floor? does this every time please help
  clio 172
i know its a real random one but this happend to a mate not a clio though he changed his caliper and put them on the wrong side upside down i believe the bleed nipples have to be at the top but dont quote on that !
  clio 182
back bleed nippes are facing down, front nipples are up, maybe you could be right, but i dont think u can put them the other way round?, it is the back 2 i have changed though.
Struggler
  Ph1 track 172
have you tried pumping the brakes a few times??
and are you bleeding them properly??
  Clio 182 cup
Had the same problem after changing my fluid, you need to have the ABS firing while bleeding. RS tuner with an add-on or some other diagnostics kit.
Dealer sorted mine out. I put almost a litre through it with no joy. Some people on hear say all you have to do is go out in it and get the abs to kick in,
but if your brakes are as bad as mine were.....you will have to wait on the snow coming back.
