Recaro Trendlines For Small People
Jekyll
Hi guys,
I have just bought myself a set of Recaro Trendlines today for my 182. They Look and feel much better than standard but i have a small problem. I sit a little low in the seat (5ft 6"). Is there any way that i could adjust the height somehow so i sit slightly higher? Thanks in advance for answers. Mark
And if i fit the 3.3ohm resistors into the connections will it erase the SERV light as well as the AIRBAG light?
Merci
You must be the first person ever to complain the seating position in a 1*2 is too low.
As for resistors yes 3.3 ohm will sort the lights. There are three wires. Leave the black one and brige the other two with the resistor. (I think)
I was also going say never heard anyone complain about seats in 182s being to low!
i know! they look the tits and feel ace in comparison to the standard seats.
just a quick update. bought some resistors from maplins today (3.9ohm because no 3.3ohm in stock) and fitted as stated above and both airbag and serv light has now been removed :approve:
and also the advantage of the trendlines over the standard seats is that they can sit more vertical too so now my seating position is not low at all. just got to sort out the runner and tilt action now
Can't you just put the seat on the maxium height? The lever on the left of the seat adjusts the height. I'm 5ft 8" and I have my seat at the lowest it will go and it still feels high, can easily see over the steering wheel.
