Ph1 and ph2 engine the same?
Exactly the same fitting too? I've got a 52 plate with climate control which needs a new engine and I've been offered a engine out of a ph1 sport
ph1 has bigger inlet valves and has a cable throttle body, id imagine you could use the fly by wire body on it but not sure if you would need the ph2 inlet manifold too, not sure if there is any other differences, but you can run them anyway i know a few doing it
Oh it's only a bare engine I've been offered out of the ph1, I'm prob best getting another ph2 engine then I suppose?
maybe not 30%, but its still a big difference!
they're not technically 30% bigger, that would be incredibly difficult to quantify, they have 30% better flow. I was there when they testing was done years ago ;)
Wow that is a fair difference. I hope the gasket I've ordered is the right one, if not i'll be using the old one.
