Wheel bearing question
Car  EP3 Civic Type R
Had a quick search and could not find an answer. Recently had a wheel bearing replaced for MOT on my 172, but after 200 miles I can hear the dreaded droning noise again :( Anyone know what could cause repeated wheel bearing failure? Oddly its a constant noise, it does not change volume when cornering right
A possibility but would be surprised. Would a knackered hub assembly cause this problem also?
I would doubt it's possible to somehow get a knackered hub assembly with out it being visible (bent or scored) when fitting the new bearing, did you fit it yourself or garage? If it was a garage take it back to them as it could be a fault or a badly fitted bearing that caused it but before you go there phone renault for a torque settings and ask the garage what they torque'd it to.
Garage, not done by myself. I only suggest the hub as I had it replaced with a 2nd hand one sometime back after a prang. Thanks for help so far, very frustrated as only just got it back on the road aswell :(
Take it to the another garage for a diagnosis, if they say the bearing take it to the original garage and ask them to look at it keeping quite about the bearing you had fitted there. If they come back with the answer you're hoping for then they should replace as a bearing is designed to do thousands off miles not 200.
