ABS rings
Car  RB 182 FF
Just wanted to check if this is the correct ABS ring for my 54 plate 182 with cup packs?
http://www.ebay.co.uk/itm/RENAULT-C...arts_Vehicles_CarParts_SM&hash=item27b49b21fc
I've got a cracked ABS ring and I figure that's causing the 'pedal fart' like others have on here, and Renault only quoted me on buying an entire new driveshaft as they don't sell the rings individually apparently.
EDIT: Also while I'm at it do the non sport arch liners fit a Sport? I assume they do but with different arches I'm just making sure!
IIRC the arch liners are different from the RS models mate as people go hunting for them when fitting bumpers to non-RS cars.
You're best bet is to count the "teeth" on the ABS rings as there are 2 types on the Clio's :)
Cheers mate, looks like I'll be joining the queue looking for Sport arch liner then
And I'll check the ring tomorrow, will be glad to get rid of this pedal judder!
Maybe a sensor issue? My nearside ring was cracked and heavily rusted so it looks like that's my issue
Could just be general crap around mine then, I had a CV boot bust ages ago but it was quickly repaired and cleaned up - used to do the "farting thing" a lot when that happened but now only get it on steep hills - randomly :S
I get the judder too but my abs rings all look fine! :S
My gf had the same and it went into rentech a couple of times before they found the problem, and he said it was such a tiny crack he had to pull the ring to see where the split/crack was so try that. ( if that makes any sense)
You need to know how wide they are, 182 cup/cup packed are wider than the rest, the thinner ones miss the ABS sensor, I know this from experience :rolleyes:
