Threaded Wheel Hub
Car  Bus Winker
I think I know the answer to this one but I thought I'd post in case anyone had any clever ideas or solutions.
I took my NSF wheel off for the first time this week to fit a new arch liner and I noticed one of the bolts was very loose.
Upon inspection it looked cross threaded and when I tightened it back up the bolt just kept spinning. I tried another bolt with the same result.
Is it possible to get these tapped out or do I need a new hub?
If a new hub is required, is the below what I would need? I know the ad states for a 172 but are they different on a 182? Would I need anything else other than new wheel nuts?
https://www.ebay.co.uk/itm/Renault-Clio-Sport-172-2001-2006-2-0-16v-Passenger-NSF-Front-Hub-ABS-Sensor/193183809223?fits=Model:Clio|Cars+Type:2.0+16V+Sport&hash=item2cfaa6fec7:g:To4AAOSwiJRduY6A
Yeah just fit a new hub setup or just the flange itself but that will require a new bearing and having a big press.
172 hubs will fit a 182 as long as yours is not a cup packed model.
Stick a second hand hub on. Very easy to swap on Clios and can be done at home as no need to mess with press machines.
Thanks for the replies everyone.
It's a 182 Trophy, I assume this doesn't use the cup pack spec?
Edit: Actually, reading this, I think I need the 60mm spacing.
Only got one 54mm hub left unfortunately. I need to get another breaker!!
My thoughts are that if you are going to take the hub to a 3rd party to have the bearing pressed out, you may as well get a new hub and bearing from Autodoc, and refurbish your existing assembly.
Front hub 7700830220
https://www.autodoc.co.uk/topran/2731654
OE spec wheel bearing 7701206771
https://www.autodoc.co.uk/snr/1928691
Alternatively, buy and fit the eBay item, and if it has a noisy bearing, refurbish your old one and refit it.
On 24 May 2020 at 11:07 MILLER STEPHEN <stephen.miller347@ntlworld.com> wrote:
https://cliosport.net/threads/threaded-wheel-hub.832614/#post-11913827
60mm 182 Cup pack hub required for a Trophy, not 54mm 172..
@Mbeau or @Midge may be able to help, otherwise there`s this on eBay.
https://www.ebay.co.uk/itm/Renault-Sport-Clio-182-Cup-60mm-Hub-Passenger-near-Side/164150128281
Cheers, I’ve bought the eBay item. I’ll see how it goes [emoji106]
