Was good while it lasted - New wheels
Car  Monaco 172
Hey guys, had trouble fitting my wheels, trying to find various things like nuts and bolts etc...anyway, got the bolts i needed and after a while finally fitted my wheels...
however, after taking a drive down my lane, on the way back my brother noticed the front left wheel was wobbling :( i hope the wheel isnt buckled, but cant really think of anything else it could be? HELP? ha
yeah the wheels are definatley on, all the bolts etc :rasp:
Swap the wheel to another side and see if the problem moves to there, if so then its the wheel, if not and its still on the left then it might be a worst problem.
brand new spiggots in, checked theyre in properly, and wheel bearing have just been done aswell :/
swapped the trouble wheel onto the back and no problems so far :) just need new tyres on two of them now and should be all sorted :)
You probably didn't do the bolts up tight enough.
Make sure they are all torqued correctly... ~90Nm IIRC ?
Looks better standard :( New wheels are at least 2 inches too small to be pulled off IMO.
Needs MEGA lows to work.
if anyone can use photoshop, a few different ones of different heights would be muchly appreciated, and anything else you wanna add (colour coding etc)
thanks in advance
