197 Exhaust Manifold Cracked!
Car  Albi Blue 197
Just found out that my exhaust manifold has cracked! Is this a common problem? Because i could never imagine an exhaust manifold cracking? Especially one that's designed to be for the sports! It just suddenly happened the weekend! I wasn't expecting it or anything! Has anyone else had this problem??? :S
Also, i'm now going to be after a manifold, so if anyone has one for sale, let me know :) - Unless it can be welded if that's possible?
Reece
seen a lot of pictures of them, and a few up close. Where is it cracked? common places are around the welds at the head flange, and on the welds of the cat
it "should" be weldable, but without seeing it i can't make promises
that was posted on 197.net
This is the problem! This is a picture of my manifold. As the picture above from 197.net, its exactly the same branch thats cracked, so there must be a problem there somewhere!. Just a poor welding job from renault lol!
looks like they've thinned the tube too much when they've shaped it to the port, then laid on a thick old bead of weld on. Weakest part of any join is always along the edge of the weld. 172 and 182 were much stronger.
That's weldable IMO, but I'd have it TIG'd rather than try and MIG over the crack
Well im doing all the work myself and getting a mate to weld it up for free. Im gunna weld over the other branches and other places where the manifold has been welded up to make sure this problem never ever happens again! All im paying for is a new manifold gasket :P
Job is a real pain in the back to do though!!! Subframe off! Or engine out? You choose lol!
we have replaced 4 or 5 now but have been in warranty, pain in the arse to fit aswel.
Dont take the subframe off, just let it hang a bit. (whilst supported)
My mates cracked and he got quoted about 600 quid, might of been more! (from Renault)
He got one 2nd hand off a 197 with 26,000 miles for 160 quid and his mate whos a mechanic is fitting it, have a search around mate you may get a bargain :)
The jobs done now mate. I took the manifold off myself and welded it up! Stuck about 3 welds over eachother! Will be extremly hard to crack now lol! The cars now running as good as it did :)
