Is it possible to fit Harnesses whilst retaining use of the back seats?
I'm sure I'll probably get shot down with this, but
I've got Recaro's , just wondering if there was a way I could fit harnesses, but still allow for people to sit in the back.
Obviously most strip or have the harnesses coming out the middle of the seats, which obviously makes them redundant.
So just wondering if there was another way.
As said, probably flogging a dead horse, but worth a shot?!
Tell me more?!
Edit: don't think thats what Im after really lol.
What do you want harnesses for then? Looks?
It does the same thing as a harness and is very highly rated. Harnesses should only ever be used with a full cage too
From what I understood, if you roll a car without a cage, but with harnesses, you risk serious head injuries because you can't move out of the way of the roof if/when it caves in!? Not sure how true this is?!
I still want harnesses though :p
Well, you can but not use the harnesses and the back seat at the same time. You can buy some road harnesses that can disconnect behind the seat. When you want the use the rear seats, you disconnect your harness and use the belt instead.
You shouldn't really have harnesses unless you have a full cage, if you have a full cage then you couldn't get in the back anyway.
