About 15/61 Gear Box?
Car  Clio 172
hello all,
ı had some problems on my ph1 gearbox and I wanna change it. As you know ph1 172 has 15/58 gearbox rate and 2.0 Laguna 140 hp gearbox is 15/61. this laguna gearbox is compatible with 172? to use 15/61 is an advantage compared with 15/58 for performans?
Is there anything to use laguna 15/61 gearbox or it's directly plug and play?
could you please tell me your experiance about 15/61?
thanks in advance
I'm not sure what the gear ratios would be like using a laguna box. If they are the same as Clio then maybe it would be ok. But the phase 2 Clio 172 box has a 15/61 final drive ratio and is more suited in my opinion. So id suggest trying to find one of those.
The advatage of the 15/61 would be faster acceleration.
thanks for you suggest but unfortunately it's very difficult to find phase 2 gearbox in turkey :(
You could always try a UK breakers and get them to post it.
thankss but the custom clearance in turkey is a little bit difficult especialy for 2nd hand auto parts :( but neverthles I would like to know ph2 gearbox price in uk, do you have any idea?
