Haynes Manual Clio 172
ths Haynes manual's worth having as there are some common areas and it'll give you the gist of things otherwise
Isn't that pdf taken from Dialogys?
Presumably contains all the workshop manuals & exploded diagrams you'd need. Takes an age to install mind.
Few typical vehicle codes:
C405 - 5GTT
C57M - Clio Williams
CB1C - clio 172 ph1
CB0N - Clio 172 ph2
CB1N - Clio 172 ph2 Cup
CB22 - Clio 182
V6 Clio CB1A, CB1U, CB1S, CB1H
Bon appétit :)
Link to manual seems to be broken. Any update on where I can get a manual. Specific interest to replace brake disks on Renault Clio 172 sport. Thanks
Yeah the manual link is no longer active. What part of changing the brake discs? It's a pretty straight forward job on the fronts, rears slightly less so.
Anyone know where I can get hold of that PDF file these days?
Bit of work coming up so want to double-check torque settings etc
Thanks
Trev
