Akay
F54 Clubman S / Buzz
Hi all,
Had my 182 for a few weeks now and this problem is really, really getting on my nerves now!
Symptoms;
Things I can eliminate;
As you can see this is driving me spare. The only thing I can think it is is the rear brakes or the steering rack itself?
Feel free to ask/dig deeper as I really want to get this sorted as its getting quite alarming now given the amount of things I have changed to try and resolve this!
Cheers.
Symptoms;
- When braking progressively, the car pulls to the left, not really sharply but not coasting either.
- At speed, the effect is worse i.e. a much harder and aggressive pull, but happens at all speeds.
- When braking hard, no pulling.
- Car drives in a straight line, sometimes a bit snatch when giving it some over a badly surfaced road but I reckon this is normal.
- I checked the amount of turns lock to lock on the wheel, turning left was half a turn more then turning right. Could this have anything to do with it?
- Tracking/Geo - Done last week
- Springs - Changed to Sportlines
- Passenger driveshaft - New
- Balljoints - New
- Track Rod Ends - New
- Tyre Pressures - Fine
- Brake Lines/Fluid - Fitted Braided lines and bled the system
- Front calipers/pads - Fitted rebuilt calipers and new pads
- Steering Rack Retaining bushes - Recently done by previous owner
- Visual inspection of bushes and arb etc all look ok
- Not been in an accident as far as I am aware
- Full CLIP diagnostic showed no fault codes etc.
- 'Road camber' - This happens everywhere from the motorway to single track roads.
Cheers.
