Correct.
A local company that regularly imports Jap. sportscars to Estonia (RHD Scoobies, Skylines, etc.) imported this one also. A female voice says something odd in Japanese when you fire it up, perhaps "fasten your seatbelts" or "lock the doors" or something with regard to the road toll memory card system that is on board. Have to check it out.
Even had a red flare in the glove compartment and the majority of stickers (incl. those on the door pillar) are in Japanese. The history of it is pretty much unknown but a VIN code check at the official Renault dealer confirmed that it had indeed been serviced in Japan.
Mechanically and bodywise it is quite sound and identical to an EDM Clio 172. I ought to make a thread of it once I get the details (MOT, etc.) sorted and some decent pics taken...
Correct.
Sounds interesting, get a Clio media thread up once you've got it in order, or maybe a project thread if you're planning on modding it,
i'm sure a JDM 172 thread would get some interest. lol
I really can't imagine a 172 driving about Japan surrounded by boosted ricers. :cool:
Correct.
JDM flare :cool:.
Fitted new tie rods & track rod ends, well when I say fitted the garage did it,
b*llocks to getting filthy and sweaty under a car on a day like this.
Handles like it's on rails now. :approve:
I haven't done anything to either of them for a while.
In the near future I will be getting a bulkhead for the Astra van and removing the centre silencer and the clio will be getting mapped.
Went out for a drive in Cheddar gorge just to drive it, which I basically never do! The entire bug population of Somerset seemed to be drawn to my front bumper.... nothing a quick wash couldn't get off, the Werkstat made it super easy.
I did nothing myself, however the cambelt was done over the weekend, the first time on a 51 plate 172 with 87k on the clock.
Washed all the dead flies and rubber off it from Donington, also tightened my wheels as since they were powder coated the nuts keep working their way loose. Its now red again
New 'white' bulbs all round inside.
Then had a massive fail with the number plate ones and blew the fuse. Great job.
Fitted new rear brake discs and pads on the RB, attempted to raise the adjuster platforms but the Allen key size is 9mm and only had an 8 and 10mm.
Washed yesterday
out all day in mine , smile , smile , smile
Ordered Spax RSX coilovers for the RB, finally... FINALLY, I can say goodbye to the GAZ setup :)
Put the stickers on the rear window.
The Karl pilkington sticker is from n2grafix off here. Cheers.
Makes me laugh when I see it anyway. I know it's not to everyone's taste.
Edit: sorry for the double picture. Couldn't delete the one on tapatalk. My bad
218 mile (wynyard to work), removed the the exhaust heat deflector (broke), oil change, and plugs changed after work :))
Filled it up, been up and down the m6 all day, picked up a new rear bumper as the cut out for the exhaust was hideous on the current one so gonna have it re done with a carbon surround fitted.
Discovered that over night it's decided to start leaking coolant from somewhere at the front. :dapprove:
Hopefully it's just a perished hose that given up due to the heat.
