Paradas have softer side walls than Hankooks
I cant see Michelin PE2's all I can see is Pilot sport 2 is that the same?
I havent seen that mentioned in any other reviews for them
Did you buy any Luke?
Vredestein Ultrac Sessantas for me. Price is crazy for the performance of the tyre. Of course these aren't £150 tyres but imo they are easily on par with the best out there. Testament to that, the Mk2 Frs boys have been firing them on for a while now, much better than the CSC3's.
Not looked at these before...interesting tread pattern...doesn't look like the water will have anywhere to go. Plus side I guess is that the pattern isn't riddled with loads of small blocks that generate heat.
So 1.5 ton FRSs are OK on these...on track?
Those are cheap Gally, my front Dunlop Sport Max have only lasted 2 and a bit months so might get these!
I'm guessing there was a lot of sarcasm in there? My detector is broken.
Well one chap, runs 400bhp jamsport and think they're the best tyres he's used. Much better than the 3's that were on it from factory anyway.
They've been epic in the wet but they are new.
I shall ask the question. Not sure how many times it's been on track. Moby might be able to tell us better. I'll ask.
WEll he has them on his 19's and done 5k. Hardly touched the tread.
On his 18" Comps with heavy use off track he's done 7k and the fronts are at 4-5mm. Baring in mind it's FWD running over 400 brake iirc.
No idea. I've never tracked a car in my life.
He did say plenty of them have used them on track and he hasn't heard any complaints.
If I was a serious track user why would you buy a midrange tyre anyway?
Is £94 for a Pilot 3 from Camskill a good price? Going back to quality tyres after having a couple of budget ones...
Have you ever seen a review of them as a nearly dry track tyre before? lol
If not then you wont have seen anything mentioned about them in that context, lol
Im not slagging them off, I love them for their wet performance and they work fine as a normal road tyre, I still use them to this day when im on trackdays that dont allow full wets (ie when they have to be road legal) but Im just trying to be realistic about what happens if you corner them hard in the dry.
'Range' is open to interpretation.
Best tyre I ever had on my 172 Cup in my opinion was Yokohama's A539. Most despised them with a passion, but I found they soaked up track abuse/heat with no issues, and still gave 12-15k miles. Not as grippy in either wet or dry as PE2s for example, but in my opinion (and based on my Llandow experience) far superior.
I'm just trying to find something that on my 200;
1. won't melt or shed treadblocks on track
2. gives 10k miles including a handful of trackdays
3. is progressive once you get them moving about
Beyond that I really don't care what brand/range they are or how much grip they have...with the above 3 things satsfied, I'm ultra happy on track.
I've got rainsport 2's as said they are brilliant in the wet, but they are average in the dry. Side walls are too soft but running at 36psi improves alittle.
Ordered some RS2's this morning, cheers all
Will report back when I have them fitted, but aim to have new wishbones/ball-joints/track rod ends fitted around the same time, so hopefully will feel like a new car.
Taking your time![]()
The biggest problem the rs2 have in the dry isn't the sidewalls it's that the tread blocks quickly end up slanted over.
One dry trackday will totally wreck them from brand new if you drive hard. You just can't use them for that at all unless you drive very gently on track.
