How do I split the rear spindle from the calipers carrier?
len_beach
Car  E92 M3,172 track car
I've just fitted a new stub axle to fix an ABS sensor issue but the stub axle is the thinner phase 1 version.
How do I split the spindle from the caliper and ABS sensor carrier to swap the thicker spindle back on?
I think the stub shaft is only pressed into the carrier so once the 4 holding bolts have been removed to free it from the hub, it should press out.
