How do I split the rear spindle from the calipers carrier?
  E92 M3,172 track car
I've just fitted a new stub axle to fix an ABS sensor issue but the stub axle is the thinner phase 1 version.
How do I split the spindle from the caliper and ABS sensor carrier to swap the thicker spindle back on?
  172 cup, Impreza P1
The caliper is bolted to the hub. Are you talking about swapping the stub axle only?
  172 cup, Impreza P1
I think the stub shaft is only pressed into the carrier so once the 4 holding bolts have been removed to free it from the hub, it should press out.
