len_beach ClioSport Club Member Car E92 M3,172 track car Jul 8, 2012 #1 I've just fitted a new stub axle to fix an ABS sensor issue but the stub axle is the thinner phase 1 version. How do I split the spindle from the caliper and ABS sensor carrier to swap the thicker spindle back on?
Cupman29 Car 172 cup, Impreza P1 Jul 8, 2012 #2 The caliper is bolted to the hub. Are you talking about swapping the stub axle only?
len_beach ClioSport Club Member Car E92 M3,172 track car Jul 8, 2012 #3 Cupman29 said: The caliper is bolted to the hub. Are you talking about swapping the stub axle only? Click to expand... I want to split the stub axle/spindle from the hub.
Cupman29 Car 172 cup, Impreza P1 Jul 8, 2012 #4 I think the stub shaft is only pressed into the carrier so once the 4 holding bolts have been removed to free it from the hub, it should press out.
