Plugs hanging loose?
Car  PH2 Flamer
Ok just had a good look and couldn't really see what they are for. But I also found a black one hanging loose too. So I have a purple one. That breaks out of the harness for brake switch. <br />
<br />
And a white one, and black on that are kind of floating behind the traction control button.<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
Any ideas anyone? <br />
<br />
Am thinking the purple one should be for clutch switch? But it doesn't have one? <br />
<br />
Baffled!
I have a feeling the purple one may be a clutch position sensor and the white one may go to the switch panel on the right hand side of the steering wheel.
Do you have one, two or three switches on said switch panel?
Right I just took some pictures of mine.
You can see the purple one going to the clutch sensor.
Untitled by sbridgey, on Flickr
I think the white one may be one of these
My 172 has Cruise control btw and yours can have it fitted hence the wires being there.
Does that cover just pop off?
Ok so I dont need the purple one. Will tape that away.
Will look into the white one in a sex and take a pic.
Black one?
Yeah it pulls away from the bottom.
Black one is either for manual headlight adjustment or a brake pedal sensor, depending on where it is.
Yep its all just cruise control wiring, nothing to worry about but you can install cruise if you fancy it.
Oh yeah not cheap. Plus I don't have a standard steering wheel.
Cheers anyway. Just taped them up an cable tied them away.
