Mk2 front and rear seats fitting removal
I had a quick search but I couldn't find anything, so here it goes:
1. Rear seats when you take the isofix bar out, then there are two torx screws for the rear seats, the back one is easy enough to get in and out with no problem. The front screw I've had to force my screwdriver into the seat to be able to get it to turn the screw but the screw is tight and the screwdriver ends up at an angle and slips. Does anyone have an easier way to do this or?
2. I understand the front seats are bolted from underneath the car, anyone got a picture of where the bolts are or a quick tip? And also what socket size they are?
Thanks in advance, Bambi.
The rear seats, you only need to take the back bolt out then they should just slide backwards.
And the fronts are 13mm nuts, with 4 bolts per seat 2 rubber grommets on the outside edge of the car that just pop off and the nuts are in there, then there is another 2 nuts near the heat shield of the exhaust.
