Horn doesn't work
d6n
Car  Ph2 172
As above, ph2 172, I've checked the fuse and it's fine.
What is the next step of problem solving?
im on my 3rd horn!!! water always seems to find its way into it! check to see if there is voltage at the trumpet with a multimeter, if yes then new horn!
Check your connector as well.
Rust can get in there.
Remove passenger side wheel (or some have managed with just turned it full lock) then undo the 2 screws holding the bottom end of the arch liner in.
The horn will be right In your face once removed. :)
thanks mate!
