Horn doesn't work
d6n
  Ph2 172
As above, ph2 172, I've checked the fuse and it's fine.
What is the next step of problem solving?
  clio 172 ph2
im on my 3rd horn!!! water always seems to find its way into it! check to see if there is voltage at the trumpet with a multimeter, if yes then new horn!
Sam
North East
Remove passenger side wheel (or some have managed with just turned it full lock) then undo the 2 screws holding the bottom end of the arch liner in.
The horn will be right In your face once removed. :)
d6n
  Ph2 172
thanks mate!
