Just fitted FK Konigsports to my 182
Car  182
As above. All opinions welcome.
Before
Add these ...
And you get ...
So far i'm happy. Bit of rubbing on the offside front which is a pain so might raise up a little bit.
Looks good, funny im just about to buy a coilover kit but don't know what one yet.
Car looks good, where is it rubbing on the inside or on the wing?
Scott.
Just on the inside, the arch line was sticking out a little bit so i've cut it off (the bit that sticking out) and now its only rubbing on extreme left lock.
Cool what does the ride feel like, i have Sportlines on my ph1 but it does not sit low enough.
Scott.
lokks good what they set you back
Cheers, they cost £630 but I like the option to adjust them to exactly how I want.
Scott.
I've only driven about 10mins in it since they've been fitted but very comfortable. Just a shame my track rod end is fooked :/ will have to sort that on Monday.
Anything over £500 seems alot for me but my god they look so shiny and new i must buy a set! Car looks ace too :)
Yes, quite a lot! I've recently put some 15" Pro Race 1.2s on and can't get my car on the drive so park on the road now. But there is scope to go lower!
Normally rubs on the metal bumper bracket on Ph2's if the fronts to low, Ph1's dont have the bracket the b*****ds!
iv got these fitted on mine, i got told if you go pretty low you will need a 5mm spacer, iv fitted 10mm and now it slightly rubs on the outside :/ will sort it out one day
This is it on the drive (just after fitting the smaller wheels)
But when the snow clears i'll be lowering it a bit more, i've already got rid of the brackets that cause the rubbing. Serious pain in the ass! And a splitter is on it's way.
