Engine poped at 25mph :'(
Car  Clio 172
As above really the bottom end of my 172 phase 2 has poped started tapping from bottom so I pulled over knocked engine off and waited bit thought right only 1 way find out turn it over and it just wen CLUNK!!! That was that now I'm not even gonna bother with rebuild just straight swap and I want to no best way of getting the big boy out of my tiny engine bay lol i need to change steering rack aswell so was wondering will it be easier to drop it complet with strus subframe on a dolly and lift car off it any advice would be really big help
If you pay to be a member I made a full guide that is very simple to get the engine out.
Sounds like your Cambelt has snapped TBH.
Cheers guys and it not belt I done it 4 months ago and I can turn engine over manually on bottom pulley but after 1/2 turn it solid wont go no more
Hi
Steering rack can be removed pretty easily once you've taken the engine out.
Think we have found the problem right there :cry:
With the horse shoe and crank pin, that's 2/3.
You still need the pulley locking tool which 99% of DIY jobs don't use and then results in a failure.
You need this and this manual to do it correctly
This sounds like the problem !
So many things you can get wrong on a belt change on a 1*2 !
I've got a week off next week gunna rip it apart then Pablo ill keep u all posted. And it not that bad oli managed to find and engine for £400 that's just had belt dephaser and water pump and I'm gonna go through it properly ill do all work my self save a load there
Started stripping car today and the wires are all to f**k they been cut and shut my mate has given me a 182 wiring loom any1 know if there's any difference please?
