C COLZO Car Racing Blue 182 Cup Oct 8, 2012 #1 If I buy OE discs with ABS ring and Bearings is it just a straight swap? What size is the hub bolt? Cheers
T Tunst ClioSport Club Member Car Focus ST225, Focus E Oct 8, 2012 #2 Yep straight swap, Bolt is 30mm iirc..
MartinR Car 182 Oct 9, 2012 #3 Make sure you have a torque wrench. If not don't change them till you have. Needs to be tightend back up to 175nm.
DrR ClioSport Club Member Car VW Golf GTD Oct 9, 2012 #5 mr.pink87 said: and don't forget the spacer that sits behind the disc! Click to expand... This x1000
C COLZO Car Racing Blue 182 Cup Oct 9, 2012 #7 Cheers lads. Got a torque wrench and wouldn't do any jobs without one! Noted on the spacer.
DrR ClioSport Club Member Car VW Golf GTD Oct 9, 2012 #8 I never used a torque wrench in the 3 times I did it, wheels never fell off.
Cupman29 Car 172 cup, Impreza P1 Oct 9, 2012 #10 Clart said: Ive never used one either. Its not exactly essential. Click to expand... Not essential but highly recommended IMO. Depends on what level of workmanship you work to.
mr.pink87 Car 172/1.2/E30 Oct 10, 2012 #11 Torque wrench is essential for these kind of jobs involving bearings as they need a correct preload.
