How good are the Dalis? Looking to replace my Missions on my PC with some...?
they dont go together becasue a record out is not for driving a sub. The manual says to connect the sub to a'pre-out', this is not the same as a record out. A pre-out is the output before the amplification stage. i.e, it is controlled by the volumn control. How you have it will not turn the sub up/down with the volumn of the amp, which means everytime you want to either A. use the sub, or B. adjust the volumn when the subs on, you will have to manually adjust the sub volumn to match.
Is there anything else you'd like to criticise about my new purchase?! I was pretty chuffed with it until you came along, thanks for that.
Yes.
I've been trying to convince myself that I don't need to replace every hifi in the house for the last 2 days.
Those Dali speakers look sexy...
Damn you, old man !!
since yesterday, the kids have watched two films and I've watched one and I've not had to adjust the volume on the sub at all since the initial setup.
I turn it off for normal telly and my music.
So the problem you are describing isn't an issue to me so far and tbh is unlikely to be in the future.
If it is an issue, my living room is pretty small so I'm not going to be too worried about walking the 5 steps to where the sub is located to adjust it.
The problem you will have with that is that you will always have to get up to adjust it whenever you alter the volume
But I don't. I've watched films, it hasn't needed to be adjusted once. :S
You and the fatty are concerned about a problem that I don't have.
Right so you've set the volume of the sub to match a certain volume on the speakers. if you turn the speakers down the sub will be too loud and if you turn them up not loud enough so not matching. You might not think it's a problem after only a few days but in time to come it probably will be...
I'm not saying any individual part of your setup is bad. It's just they don't go well together and I think the sales man you dealt with was poor.
Richer Sounds own a large part of Cambridge Audio iirc. Makes me wonder if the sales people get more commission when they sell them!
i hope you bought the warranty for the amp (and possibly the sub)
as i've just sent my cambridge audio amp off for repair after i believe it killed one of my mordaunt short speakers
My old Cambridge audio amp is 15 years old and still going strong.
As your is in Wales, its probably rusty.
But yours doesn't work! lol.
