Cams, ITB's and a supercharger....excessive, cool, or pointless?
I suupose aslong as you can get a sensor where the calibration is the same as the OEM one, you could fit a bolt in one?
Given that I would be using aftermarket for any project like this, you can calibrate whatever sensor you want (within reason)
Speak to Jamsport they have run turbochargers with ITBs on one of their employees Fiesta ST's so id assume the principal is the same.
I was sceptical about it because of the massive drop in torque mid range too. With that in mind I will remove it and run it standard single speed
