BIN WAGON! :rasp:
well with my next trackday coming up next weekend iv got loads to do before then
:-sort abs
:- fit new cold air intake
:-spray wheels
:-fit new disks
:-get new caber bolts in
:- get the cmber redone with new bolts
:- paint rear floor
:-general clean
:-oil and filter change
:-gearbox oil
looking at that list there isnt really that much that deffo needs looking into but its needs doing
also got my new gloves today after ruining my last pair of mountin bike gloves i had used, not bad for £20 posted
IMG_2043 by MSPhotographic, on Flickr
Those green wheels locked nasty IMO, not going for 15s?
Ordered a set of those gloves, cheers for the link. And the black wheels look way better.
The lighting loom earths are behind the passenger headlight iirc and one behind the drivers headlight too, 15mm I'm sure, maybe 13mm
Check all the fuses and unplug and plug all connections on the headlights again Incase it's a bad contact.
Making some good progress![]()
Looks well, I wouldn't bother fitting a cage unless you are planning a full cage as it won't make any difference but make your car heavier.
Apart from increased safety?
Looks like it goes well - well done.
60mm! jesus, never new they did more than 30mm ones, why that much? Surely you wont need one that big??
t-rex arms?
Car looks awesome above on track!!
Nice one, does the spacer come with the necessary bolts to fix it to original hub?
