197/200 boot rattle - neat fix!
Car  197CUP
Sure this may have popped up before but I struggled to find it so this may help some people;
Had my 197 for about 3 weeks really happy with it apart from one annoying rattle coming from the boot which has been bugging me since buying it! Found it tonight - turns out its the boot catch rattling against the metal loop.
I've wrapped some black electrical tape round it (3 or 4 times) this has stopped my rattle and it also make a much nice noise when you shut the boot as before it went with a fair old clatter!
Hope this is helpful to someone as it has been to me!
Quite a common problem mate, the tape trick seems to be the most used method to fix it too.
I slackened the striker plate off and adjusted it towards the front of the car a few mm so it pulled the boot in more. Worked a treat
Sounds like you've done it the right way and I've done it the easy way lol - seems to have done the trick for now though so I'm pleased :D
Same with mine and with my coilovers on its make a right old rattle! Gonna try fix this tomorrow now :) thanks for the reminder!
Interesting! I have a mk3 non sport and this has annoyed the piss out of me since owning it! Think I'll give the tape a go, can't be arsed with faffing around with moving the plate :p
I moved the plate originally, but it only helped for about 2 or 3 weeks. Tape has been on for months now and it's been perfect!
have you got a picture of the bit you taped up I have an annoying rattle at the rear :(
At work ATM mate but I'll take a quick one for you tonight and post it - it's basically just the metal loop that the boot lid locks down onto. Right infront of you when you open the boot - can't miss it
Very common fault on all mk3's. another way of fixing it is to put a bit of grease on the moving parts on the locking mechanism.
