Timing out????
Car  Clio 182
Hey guys I have a clio 182 and I have been on a dyno today and with a forge silicone intake hose rstuner remap and k&n panel filter and custom exhaust my car is only creating 155bhp it runs ok but it had a timing belt before I purchased it and was wondering if my timing could be slightly out the only other fault is the diphaser pulley is slightly noisy but you have to have the bonnet up to hear that thanks guys
Could be or could just be the rolling road that you used.
I did my belts on my ph1 and it made 171.8 bhp on TDF rollers. (just ITG filter)
Does it run different with the dephasor solenoid disconnected?
If its not working that would also cause a big drop.
Failing that though, timing is certainly likely to give that sort of drop if its out by a fair margin.
I don't think it was the rolling road as I know the guy that owns it and know it works fine might have to have a look at the timing then
This was the best run
