One key wont start the car?
I've got a 1.2 2005 clio with 2 keys, one key will start the car first time with no problems at all but the other will not start the car, the immobiliser light flashes and stop comes up on the dashboard, if you press the lock/unlock button sometimes it will start but not always. It always unlocks/locks the car with no problem, just fails to start it so I'm a bit confused can anyone help on this? Thanks!
They have a little chip inside them that is read by a ring around the ignition barrel when you put the key in
If someone has had a cheap copy made in the past by just cutting a matching key then it will open the doors/boot fine but won't disable the immobiliser so the car won't start
Transponder is bust, thats the chip that talks to ecu I think, Im a locksmith but only domestic and commercial..
It's strange because as I say it looks exactly the same as the other key, and can remotely unlock and lock the doors with a click of the button and sometimes it will start the car. If it was the transponder or whatever how would start the car on occasions?
I don't know enough to help Im afraid, maybe faulty connection?
debris inside??? Keep it as a spare..
Once again, it's the key.
Nothing you can do with it, the transponder is faulty.
No point in reprogramming it because the central locking is working (which means its paired)
Either go to a a good locksmith or renault.
Try:
guide said:
CLIO II, KANGOO & MASTER INFRA RED RESYNCHRONISING
guide said:
1. Turn Ignition OFF.
2. Press the central door locking buttonin the car for more than 5 seconds.
· Note :the door should lock then unlock.
3. When this happens, 10 seconds is allowed and the immobiliser warning light should illuminate.
4. Point the 1st key at the receiver and press the button twice, the doors should then lock and unlock. Repeat this for other remotes as required.
5. Check that the remote control unlocks and locks the doors.
LAGUNA II & SAFRANE II INFRA RED RESYNCHRONISING
2. Press the central door locking button for more than 5 seconds.
· Note : the door should lock then unlock.
3. When this happens, 15 seconds is allowed and the immobiliser warning light illuminates.
4. Point the 1st key at the receiver and press the button once, the doors should lock and unlock.
5. Point the 2nd key (if programming a 2nd key) at the receiver and press the button once, the doors should lock and unlock.
6. Check that the remote control unlocks and locks the doors.
CLIO II, KANGOO & MASTER RF RESYNCHRONISING
3. When this happens, 10 seconds is allowed and the immobiliser warning light illuminates.
4. Press the remote control once, the doors should lock and unlock.
5. Repeat for second remote if required.
LAGUNA II & SAFRANE II RF RESYNCHRONISING
5. Press the 2nd remote control once (if programming a 2nd key), the doors should then lock and unlock.
CLIO RE-SYNCHRONISING
1. Lock car manually
2. Unlock car manually
3. Insert key into ignition within 30 seconds.
4. Turn ignition and start vehicle.
MEGANE RF RESYNCHRONISING
Hold the remote control button down for longer than 10 seconds c**til the red telltale light on the key extinguishes) then press it again 3 times.
Check that the doors lock and unlock correctly.
MEGANE WITH EARLY REMOTE (LED SWITCHES OFF WHEN HOLDING
BUTTON DEPRESSED)
1. Ignition ON
2. Press and hold the central locking button for 5 seconds
3. LED on the dash board will go off, come back on and begin to flash. The flashes correspond to the first digit of the 4 PIN security code - release the button when the first digit has been 'flashed' and then press the button again.
4. Wait for the second digit to be 'flashed' then release and re-press the button - continue until all digits have been entered.
5. If you have entered the code correctly the LED will then go out and the car can be started - to code the remote, switch off the ignition and press the central locking button again.
6. Press remote button 2 times within the immediate vicinity of the pick up (in the roof) On some vehicles you may need to switch the ignition back on to achieve this however.
