The 'I wish I'd never started this job/mod' thread
I don't if there is a thread already like this already but lets start one anyway!
Ill kick it off with trying to replace my scratched up heater unit, received a new one today and still can't fit it reckon I'm going to have to talk half the dash out! :(
Lol I felt like that around about here
Fitting buckets in my MX5 with some super low brackets.. I almost gave up, dreading removing them to fit my new cage.. tears might be shed!
When fitting coilovers to my Corsa C... Did everything fine and then couldn't get one of the bolts which attached the strut to the car, took me nearly 1.5 hours for this one bolt!
f**king ball joints. I should have just replaced the entire lower control arm instead. Such a massive pain in the arse.
That's nothing! 1.5 hours!? The bolt running through the ball joint took me SEVEN HOURS to remove on a cold November day. After 500ml+ of WD40 was used, a number of sockets rounded off, bars, extenders, a hammer, a log, a brick, lots of swearing, blood, tears, and a smashed wheel arch liner, it came off. Then and only then could I find that carparts4less gave me 172 ball joints and not 172 Cup ball joints. I definitely said "I wish I hadn't started this" when my car was stranded for 2 days and I was forced to fit this ball joint in the dark and rain.
You don't mean that! ;-)
I do. If someone offered me £2000 for it (It owes me £6000!) i'd take it. Caused me nothing but grief from day one and come quite close to causing a divorce. Several times! lol.
There are many ph1 owners that know this feeling.
It's like "ohhhhhhhh s**t, should I have really done this?"
Yep! At this point, The ph1 dash wasnt actually that bad afterall! After all this it was ripped out, Because racecar :( haha
