Any auto electricians out there please help!
Car  197CUP
Boot catch has been playing up terribly (popping open everytime I unlock the car) it's been happening since removing the item in the photo - which is a sort of sticky back plastic thing that was attached to the front face of the boot catch just hidden by the trim panel. It was poking out one day so i stupidly decided to pull it out!
Can anyone tell me what it is/does?
You will find its corroded aswell as wet so a new one is the only way to fix it 100%.
It's the actual rubber switch you need. If you take the old one apart, you will see the problem.
You will find its corroded aswell as wet so a new one is the only way to fix it 100%. It's the actual rubber switch you need. If you take the old one apart, you will see the problem.
Brill thanks for that mate!
Taken it off and opened it up - as you said it's covered in green copper oxide slime! New one ordered :)
