Clio extreme4
I'm after my boring orange changed to blue and white does anyone on here do it on her
My clio has the LCD display for the fuel and temperature readings on instrument cluster and I've heard thy have different led from the rest of them or something, is this true
So where do you get the LEDs from for the instrument cluster? You got Any pictures of you LEDs? A don't mind buying you a crate of koopernerg for doing it and I'm from Newcastle upon Tyne
With the center LCD you need 4 PLCC-4 3254 SMD in the colour of your choice then 4 PLCC-2 3254 for the dials
So what would a need for my instrument cluster the same as yours? And also radio screen, is it possible to change my heater controls colour as there twist nobs not climate control
You mean you want to open up your pioneering to change the colour?
If so it's not worth the effort![]()
I would personally not buy the kit as it's overpriced. Just purchase what you need.
With the center LCD you need 4 PLCC-4 3254 SMD in the colour of your choice then 4 PLCC-2 3254 for the dials.
For all other MK2 dials you'll need 10 PLCC-2 3254.
i will go and destroy the stock radio, lol.
That looks insanely good!!
Shame I'm such a techno spaz.
Temperature controlled soldering iron and a stopwatch lol.
Too much heat for too long - frazzled smd.
Too little heat and little time you risk damaging the contacts on the pcb.
Where do a buy the LEDs from
Is the 10 needed just for behind the steering wheel or the other little bits too?
If you can get the heater panel out from the dash there are no problems with the cables when refitting them.
These look great, what colour would you suggest and how much Mforan2012? I'm not to far away from you.
http://www.crazyleds.co.uk/Clio-MK2-Full-SMD-LED-dash-conversion-kit..html
Mforan2012 reply
