What tool for removing wire from connector block?
Car  Clio 197
I need to remove a wire from the standard type connector block to the rear lights (not a clio but an alfa 147) but I am not sure on what tool I need , the local motor factors were non the wiser , any ideas?
Once removed from the block I need to replace the metal end (which plugs in the connector) as its corroded.
Thanks
Modified paper clip works well, was the universal Renault tool most of the time until Renault brought out the removal tools.....;)
Thanks for the input , I managed to give it a clean up and adjust the contacts using a mini flat head - working fine now. Cheers :)
