182 style manifold and decat - worth while?
That manifold will probably loose you power.
To fit a 182 manifold the sub frame needs to be removed or the cylinder head taken off.
Just not worth the effort.
I was told that the main difference between a 172 and 182 was the manifold not sure if that's correct? I was thinking of just getting the ktec decat to match what I have. Bearing in mind the extra hassle to change the manifold. These just seem quite reasonable price compared to buying a decat from ktec.
I have a Renault 182 manifold that I will be fitting to my ph1.
The head will be coming off for porting and its having cams, Im after a bit more mid range punch which is what the 182 manifold gives.
172 manifold is 4 into 1
182 manifold is 4 into 2 into 1
I prefer the 182 manifold personally but I only fitted it as I was doing other mods as above.
On its own its a PITA to do for little benefit really.
