oil additive to stop engine noise
Car  golf gti turbo
hi is there any good engine oil additive to quiten engine noise thank you
is this any good
Lucas Engine Oil Stop Leak Smoke Noise
Engines do make noise, wouldn't start adding s**t with your oil because I doubt it will make any difference at all.
I was apprehensive until I saw 'it works!' On the bottle.
my last car was a Toyota cilica it had a small rattle my m8 put some thing simmiler to this and it made it not as loud
But an engine and a gearbox have very different oil requirements.
Give it a go but it certainly isn't something that I would ever use or recommend.
I have seen a demo of the stuff on cogs it makes the oil stick to them more
Ignore it.
The demo would have been with REALLY s**t oil - you any decent oil and it will provide more than enough protection.
If you look at independent reviews you will see they do more harm than good - this is VERY well known
Modern oils do a fantastic job, and adding additives to it WILL cause more problems than good.
If you have a noisy engine then there is a really - if it is tappity or making funny noises then you need to get it correctly diagnosed - if you think about it what will an additive do? It PHYSICALLY cannot make a worn engine any better - you can't mask it and as I have said modern oils are fine - the additives will just break down the protection the oil gives
any decent make is plenty good enough mate, Castrol, Mobile 1, Shell etc etc
Make sure it is 0w40 or 5w40 and must be Fully synthetic - Renault recommend 5w40
If you want to go a step further, get some Fushe titan pro S - it is ether based and is s**t hot
That little bottle contains small Chinese men that are poured into the engine and they then run around, stopping rattles.
Srs.
Well how come it made mine sound even more of a tank ? :( i r disappointed
The little chinese men aren't tall enough to reach the Diesel particles, so just ran around making more noise. hence your engine sounded noisier.
Hope that helps.
