Clio 182
Hi i have a 182 that in the last days i have noticed noise from the middle of the engine were cams sit,,,,Does drive fine and no other issues,,
I have taken to a clio specialist today who seems to think that i have scored the head, due to oil blockage and possibly starved the cam for a split second of oil.....
he also said that it could be the bearing in the power steering pump.... he said he would like to oil pressure the car, and taking the assumption that the pressure is down to then proceed to run the car without aux belt see if noise still there and if so continue to remove head and investigate the cams, if scoring seems to be the issue then to weld and skim the cam seating.....
although im desperate to get the car fixed im at stand still with what to do and this obviously is the only opinion i have as yet, not happy the thought of having welded or skimmed would the car be ok or would that fail eventually????
im thinking maybe new engine? or has anyone had this done b4 and has been ok??? i dnt mind spending the money if it going to be a deffo fix or few thousand mile going to be in same boat???
opinions and advice would be greatly appreciated as im going mad and honestly do not know no what to do for the best!!!!
thanks Kelly x
thanks Kelly x
