Best place for axle stands
What is the best spot to put axle stands under the front of the car? I don't have access to a lift all the time so would be good to know as I rarely use axle stands.
Michaelfoz
  Clios
if you look under the car you will see the spider plates.
The two "beams running behind them" we use them
As close as you can get to the front. Then you can lift the back up without a jack. Couple of stands under the rear and your up off the ground.
Clio_stu and fraser J have stripped cars with this method so its fine lol
i've also done my gearbox this way with no issues.
If you do feel uncomfortable about it then you can put something heavy in the boot haha
As above. The lifting of the rear only really works on a stripped motor with no weight in the back.
I did nice put the stands about to far back and the car started to see-saw. LOL
Just after the D plates is where I use.
I'll have a look later but not 100% on where you're on about.
Jared- the jacking point? There will be a jack there!
  M3, Cup racer'd 182
Never use the sills or enless you want to have a rotten sill from the seams coming apart, i allways use the trianglar brace plates to the front on the nuts to stop it from slipping.
  A special one.
I use the chassis rails, just behind the bolt on triangular braces.
This.
My rears are on my sills as my beam has been removed.
  182/RS2/ Turbo/Mk1
Lol, yeah there, but like fred says, get as near to the triangle bit as you can.
And accept that you should probably touch the underseal up every few years if doing so a lot as its going to get chipped off.
