GoPro Mount
LeeRS
I can’t find a good angle for my GoPro on trackdays using the cage. Especially with the mount I have at the moment as it either sits to high or to low.
I remember seeing a while ago there was a mount that went between the two bucket seats and mounted through the harness holes in either seat.
I’m not sure if this was custom made or it was an actual thing.
Any ideas?
LeeRS
I’ll get some pics of where it’s mounted at the moment.
I have a hero 7 and it always looks really zoomed out and fish eyed.
Pic below of the view, as you can see it’s really high and the actually image itself is very high in contrast.
MarkCup
Ah 😂 I read your post wrong.
Didn’t realise there was a narrow view on there.
I will have a look through the settings in that case.
In the good old days GoPros had a 'spot meter' setting that meant it always adjusted exposure to the center point in the field of view. Worked really well for fixed in-car cameras.
Now, you get to choose by tapping the screen to set where that focal exposure spot is in the FOV.
The trouble with that is that, for the likes of us that have a fixed camera needing capture through a windscreen, doing that every time you want to record is a) a pain in the ar$e and b) often completely impossible if you're strapped into a seat and just want to press go.
As @JamesBryan says, the way around that is narrowing your field of view so that more of what you capture is just the view through the windscreen...then the automatic exposure tends to work. You don't get such a wide view of what you're up to in the cabin though, and the best/only way I've found of doing that is running a second camera.
LeeRS
What I tend to do is open the boot and press record so I can see the screen and that it is recording before I’m strapped in. So setting a focal exposure spot may be possible.
I’ve had it a few times where I’ve been out, thinking it is recording to end up with just a photo at the end 🤦‍♂️
LeeRS
New mount turned up and I’ve tried a few angles with it.
What do you reckon to this?
Quality is poor as it’s a screenshot off my phone from the GoPro Quik app.
Neil Clio 182
  Audi TT RS Clio 182
Not a great vid just a bit of road driving to find noises. But you can see the field of view on 1440/60 hz
LeeRS
Since my post above I’ve been and bought a hero 10 black.
The hero 7 white doesn’t allow any change of lens or white balance so I was fighting a losing battle.
Just charging the hero10 now and have had a look through how many settings there are.
Anybody using a hero10 black in car and has a preferred setting spec for them?
Neil Clio 182
  Audi TT RS Clio 182
I just remembered my cage is T45 so it is thinner, double check the clamp specs might not go round a standard steel one.
LeeRS
So I have the mounts I need and a new GoPro.
Going slightly off thread topic but what programs do you use following recording your day?
I’m thinking of getting Harry’s lap timer GP so I can overlay the track layout and speeds etc but not overly sure how this is done.
From what I’ve seen, I turn on GPS on the GoPro which then creates a file in the background.
I run Harry’s lap timer just as a lap timer at the track day and then somehow sync this with the GoPro footage.
Is there more to it that that or a simpler way?
Any advice / links to informative vids appreciated.
Mr Underhill
Race render is good. Just load your footage in itll calculate your lap times, speed, etc.
Nice little overlays as well.
There‘s a video here with multiple GoPro angles. I used to fix one at the front and one from the cage, just to the left of me. Then sync together using race render.
LeeRS
Race render calcs the lap times without data?
  Clio RS 200
I use a set of GoPros but the GPS signal on them can sometimes be poor. Even when they have been outdoors doing laps every now and then they will lose the GPS signal and that then means you lose data about speed and track position. You can buy a separate GPS receiver to go in your car to accurately record your GPS data. Mobile phones are generally restricted to a GPS update rate of 1hz but a proper GPS receiver will give you an update rate of 25hz
My set up is:
1. Record video footage on a front facing GoPro and a read facing GoPro.
2. Use a RaceBox Mini S www.racebox.pro to capture the GPS data and lap times.
3. Once I have all the video and GPS data import it in to a RaceRender template - then sync up the two lots of video footage and the GPS footage.
RaceRender will then be able to display information like speed, track position and lap times depending on the display elements you are using. RaceRender will allow you to sync all of the your video and data and create a video that uses those separate sources of information. In the video I posted above the speed is recorded by the GPS receiver and does not take the speed measurement from the car. The timing is based on the GPS data. The bits of video footage have been synced so even though they started recording at different times. The rear footage reflects what is going on at the back of the car at the same time as what it going on at the front of the car. RaceRender also allows to you manipulate video so the rear footage is flipped horizontally to show what you would actually see in a rear view mirror. If wasn't flipped cars that approached from behind on the passenger side would appear in the video to be on the drivers side.
I started using Harrys Lap Timer but I found that it was bit cumbersome on an iPhone and the files it was generating were difficult to transfer due to their size.
I run RaceRender on a Mac and it works really well.
My only criticism of RaceRender is that the software is now getting old and I have not seen it updated for about 2 years now. I doubt it will ever be updated again.
KitsonRis
Dont forget some tracks will want a secodary tether for the camera. I was caught out on this at Angelsey last time out so have bought soem metal cable things that loop around the bolt for the camera to mount and then around the view mirror.
LeeRS
Sorted with the mount now, ended up buying an extension like above and also bought a hero 10 black.
Next question regarding mounts…
I want to mount my iPhone so I can not record lap times.
Any recommendations on a mount / position for this in a 172?
KitsonRis
Pricey but amazing, will need to also get a phone specific cradle to screw to this which they also do
I've got one on my E34, the girlfriend has one in her Focus and I had one in my old Octavia and they are perfect. No damage to the car, strong sturdy mounts that do not move or vibrate around.
LeeRS
I saw these but it’s just the leadtime on having the vehicle specific cradle made as I want it before CSF.
Clart
Think of getting something for my next track day - will a 4 silver and an official mount be ok to attach to the cage?
I know its an older device but should still be decent quality
JamesBryan
My Hero 3 Black is still decent enough quality.
The older ones are better/easier to set spot metering in my opinion.
Only downside is the batteries don't last long, so i had mine plugged in constantly via usb.
Mr Underhill
I use an adapter in the cigarette lighter to power the camera via USB. I've also used Anker batteries. As mentioned, modern camera batteries tend to run out fairly quickly.
MarkCup
Picked up a cheap gopro hero 8 which does seem to do spot metering but you have to set it every time the camera reboots. The battery doesn't work but i'll just hard wire it.
Would this mount be ok?
If that fits your cage, yeah it should work OK.
As for the spot metering, that's why my love for GoPros with screens has never been strong. It's all well and good having a variable spot meter location that you define each time you fire it up to record, but that's no good when you have the camera hard mounted while you're strapped in in the pitlane waiting to go...and you can't get to the screen or even see it to correctly set the spot location.
If only they had a default central spot option as per the earlier cameras, it would make in vehicle mounting blissful.
