Black 1988 Renault 21 Turbo
DaveL485
  21T, 9T, Meglio, V6
What? Another one? Yes, another one, seeing as one of mine is away for bodywork I thought I would squeeze this in.
This is a friends car. Really nice on the body, suspension, brakes all work, not bad at all. But the engine, sadly, rattles like someone took a bag of spanners on a buckin bronco.
Ready for surgery
Started on it at half 2 Saturday afternoon, with a plan of getting the engine out, then tackling the gearbox and subframe at a later date, however, unusually, things went spiffingly well and I got the whole lot out by half six :)
Was fortunate with the subframe bolts to be fair, three came out OK and I only had to chop one off, and even then it wasnt seized in the collar and just dropped out. Relief! I've spent multiple sessions battling subframe bolts before now!
Both in bits now!
My other active threads:
Renault 9 Turbo https://cliosport.net/threads/phase-1-renault-9-turbo.823533/
Renault 21 Turbo https://cliosport.net/threads/1988-red-r21-turbo.842581/
Renault 21 Quadra https://cliosport.net/threads/my-renault-21-quadra-supershed.821989/
Clio V6 https://cliosport.net/threads/my-clio-with-the-engine-in-the-wrong-end.820665/
Clio 200 Trophy https://cliosport.net/threads/liquid-yellow-220-trophy.840797/
DaveL485
  21T, 9T, Meglio, V6
I havent been updating but I have been working away on this.
Yuk
Degreaser and pressure washer
Powdercoated subframe with new bushes
Blasted the engine mounts and gearbox mounts
New fork
DaveL485
  21T, 9T, Meglio, V6
Blasted a few other bits, and sent a load off for powdercoat
Before
After
Gave it a size up, made sure the bespoke clutch would fit. It did :)
Before I refitted the drivetrain I welded up some holes in the bulkhead left from an aftermarket AC install
DaveL485
  21T, 9T, Meglio, V6
New driveshaft pins
Arch liners refitted, as this wasnt done after it was painted
Suspension back in with new wishbones, balljoints, and polybushes on the outer ARB
Few more bits bolted in - found a water leak from the oil cooler body
Sourced a used oil cooler, now the fan switch is leaking! FFS. Still, got a heat cycle in so time to retorque the head bolts and set valve clearances.
Almost ready to test
DaveL485
  21T, 9T, Meglio, V6
Was on the original fan loom so Jamie OK'd a new one to be built
Can you spot where I ran out of spiral wrap? LOL
Also waiting on some new fuse blocks to go by the power feed, they arrived yesterday so thats the next job. otherwise all working, both fans come on full speed. very effective.
DaveL485
  21T, 9T, Meglio, V6
Soooooooooooooooooooooo obviously as the car was nearing completion a kick in the teeth was due. It started running like crap and even dropping cylinders. I did some diagnosis and the compression test on 1&2 was waaay low, in fact all were shite.
Something not right here at all and the only way to diagnose a problem like that is...
Checked a few bits and bobs and then found this, which is pretty damning. So much for the prebuilt tall engine eh.
