ECU tuning
  Clio 2 F4R 780
Hi!
I own a clio mk2 ph1 that came with a 1.6 but now it has an F4R swapped into it from a laguna (f4r 780) it has a sports exhaust bmc air filter and an rs clio exhaust manifold. Would it make a difference if I got the ECU tuned? Currently its around 150-155 ish hp does 0-100 in 7.9seconds (used a draggy).
Brigsy
  T.Turbo
Fairs but would it also improve on fuel consumption since everything is more in “hamorny” no?
If fuelling is adjusted correctly it will most likely be a little bit better when driving normally.
