Good point, and on top of that I have had no undertray on since working on it so cooler again 🤔It's been a lot cooler weather though.... 🤔
Mine always used to fault when the ambient air temperature was above 20°cGood point, and on top of that I have had no undertray on since working on it so cooler again 🤔
Why are we thinking the capacitors are the culprits? Where has that thinking come from?
Badge covers look good. Sounds like its fixed ok with 500 miles no issues.
Hopefully that’ll serve you well.
The trophy box is better/ stronger /more reliable too isn’t it?
possibly 🤷♂️ id hope that the later the box, the more updated it was. That was my thinking anyway.
Watch it bite me in the ass and the later stuff isn't backwards compatible..... 🤣😭
Mine was definitely heat related, perfect winter car 🤣So woke up early, car drove fine, set off at lunch time and it seemed a little sluggish but covered 75ish miles (temp getting up)
started it about 30 min ago, full blown wobbly and not engaging anything, both shift drum actuators not finding position (very hot outside, car saying 34!)
I had a look at the live data and the amperage for the shift drum current was all over the shop when not doing anything and the positions were shooting all over the place too. You can hear when they try and find home and even forcing a position reset using the diag wouldn't make them play ball. Defo a temp related issue in my mind.
Anyway, I had a mot booked for tomorrow which I will have to cancel and hopefully rebook. All being well I can swap out the TCU from the trophy bits when that turns up and get it going again early next week. Will have to bust out the R8 for some more daily duties...
