RB 182 Cup - keeping this one
Darryl_1983
  RB 182 Cup
I've been meaning to start a project thread for this car for some time now. I bought the car in March 2018, and it's changed a few times since then in terms of usage as it was originally my only car, replacing a Z4 3.0i. It was then a second car when I bought a MR2 Roadster, but that only last 6 months, before the Clio was my daily again. And now it's a second car, as a change in jobs, meant commuting from Nottingham to Derby, I figured a more comfortable quieter car would be better to bought an e46 320cd.
I've owned 4 Clio 182's since buying my first in 2013, and actually owned one twice. I basically want to try something different, realise i preferred the Clio overall, and how much cheaper the Clio is compared to anything else of similar performance, and sell up my purchase within 6-8 months and buy another Clio.
I've not got many pictures at the minute but, when i bought the car it already had a decent list of parts i'd have wanted to fit straight away, which is why this car stood out so much over many others, and why i paid more than i had previously for any of my other 182's. So it had:
Evo 6/7 recaro seats of Jon Foz lower mounts
330mm omp wheel with crusie buttons
15 inch team dynamic 1.2 with AD08R
Rear seats removed and carpet added
Also supplied with the car was a set of cooksport springs and black insert headlights.
I then purchased a Scenic shifter that had been modified, a ktec Janspeed non res exhaust system, powerflex dog bone mount, yellow engine mount insert and exhaust mount inserts, and fitted the cooksport springs, and pretty much kept it like that for a while.
Then i decided i fancied another convertible, so bought a MR2 roadster with a broken gearbox cheap, and this car then became my weekend car, though i'd still drive it to work once or twice a week depending on the weather.
So I decided to add a PMS shifter, the added vibration from the shifter was both awesome when thrashing the car, but annoying as hell when driving at a constant speed. So when the car became my daily again i sold it and replaced it with another Scenic shifter.
In that time i'd also fitted a 2.25 inch decat pipe, which made the car quite a bit louder and raspy.
When i sold the MR2, i also bought a cup rear bench and parcel shelf, fitted a sleeved centre resonator and kept the decat, to try and quieten the noise inside the car. But it lost a little of the enjoyment out of driving it whilst driving it for fun.
At this point, i was also getting pretty annoyed with the seating position, even on the jon foz lower recaro mounts, i felt the seat needed to be a good 2 to 3 inches lower for my preferred position. So started looking at my options. I didn't want to fit bucket seats again like i did to one of my previous 182's, as it was still a daily driver and the actual seats i found pretty comfy.
I started by fitting a pair of mk1 mx5 seats directly to a set of jon foz X-Low bucket seat subframes. This worked pretty well in terms of position as i'd probably dropped over 3 inches easily. but the set just didn't have the support i needed. So started measuring up the Recaros again, and figured that it was possible to mount them, so that the base of the seat was level with the exhaust tunnel top. Thus approx 30mm off the X-Low subframe, as the Recaro seats where just a few mm's too wide to sit to the side of the step in the mount. This allowed my to drop the seat approx 75mm over the lower recaro mounts. The pictures below show the difference between the lower mount position of the passenger seat and my new mounted position.
So, when i decided to move for work in september this year, during my 3 month notice period, i started looking at options for my new drive from Nottingham to Derby and the large percentage of motorway speed roads i'd be driving. I really didn't want to replace this car, as i knew i'd regret it and buy another one. Most likely expensive, or not to this specification and i'd need to end up buying all the parts again, so again expensive. Plus nice ones seem to be getting harder to find.
So after looking at various options i ended up buying a e46 320cd.
Since then, i've had to get a sports Cat made up, as the original Cat material is loose inside the Cat, so rather than risk loosing that precious material inside, i figured i could either buy a cheapo cat of ebay for like £60 for mot times and run a decat the rest of the time, or just fit a decat and forget about all the hassle of switching it back and forth once a year. So went with the sports cat. I managed to purchase a miltek decat using a 20% off code on ebay, so that cost me about £35, then went for a Magnaflow 200 cell cat over the cheaper non branded stuff, this was about £75 at the time. Then got Dann to weld it up for me being fairly local.
Fitted the cat and it went straight through the mot, well once i'd changed the rear brake hard line. and surprisingly, the noise didn't really change too much. I also remember the car being much quieter with the standard cat on. But as it wasn't daily anymore, i decided to fit a sleeved exhaust straight through section to remove the centre resonator i'd previously fitted. The exhaust looks a little messy now. but sounds awesome, just a little on the loud side, which is what i wanted really.
Going forwards i've not fully decided on what i'm going to do with it. I'd like to do a few track days next year but not sure how far i'd like to go in terms of modifying this into a track car. as it's still mainly going to be a road car for weekend blast with the occasional commute to work.
So i'm thinking these will be definites:
Braided brake line kit, with ATE Typ200 fluid (used previously and in the car now from the hardline change)
Updated pads - thinking PBS pads at the minute
Coilovers - Leaning towards Bilsteins due to the mainly road usage, but will consider BC Racing and MeisterR (assume these are due for release soon?)
Remove fog lights
Fit black insert headlights finally
Thinks i'm not sure about yet:
Completely stripping out the remaining interior, keeping the dash
Fitting bucket seats
Rear bolt in cage with harness bar to allow harnesses to be used.
PMS shifter again
Roll centre correction kit
lower steering wheel kit (bucket seats in lower position would mean the wheel would be a little too high)
Trophy/V6 rep spoiler
Track tyres instead of the usual AD08RS, NS2R, RS/R, etc
Not sure if some of the above options may be a little too far for the road and might push it too much into a track focused car, thus spoil the experience on the road
Any these photos are from early 2019 i believe, so similar to how it sits now:
Looks a very nice car. I can see the appeal of going back to the clio. My mind works like this:
1) this car is so boring, I want something interesting
2) this car is so noisy and breaks all the time. I could have something nice for the parts it’s costing me.
Repeat.
Darryl_1983
  RB 182 Cup
Couple of Youtube videos from a while ago:
Love this exhaust:
And a quick 0-60 to gauge which surprised me:
Darryl_1983
  RB 182 Cup
Also forgot that this weekend just gone, i fitted a vibra technic upper gearbox mount, as the standard mount was feeling a little sloppy, and it was affecting gear changes at higher revs.
I already had a powerflex black insert upper engine mount, and purple dog bone mount, this was the last one that needed upgrading.
It's added a lot of stiffness to the engine, but very surprising no noticeable difference in vibration inside the car.
Which also remains me. I'd quite like to start adding new bushes throughout the car to freshen it up. It's had new track rods and various bits in my ownership, but really needs new bushes i think. Obviously choice for these is powerflex, but will likely be a combination of new oem and powerflex bushes thoughout.
Also was considering getting a PMS RARB next summer. I've never had one of these, and really fancy giving one a try, especially when on track. My only concern is using it when it's wet as the back end is much looser with these fitted.
I have a white line RARB. I’m sure the PMS one is similar.
In general people advise disconnecting them in wet conditions for this very reason. Just remove the link to the bottom shock bolt on one side and you will be fine.
Clio_fool
I've got a 19mm pms rarb and not crashed in the rain yet. It's set on the softest setting though and you've really got to be throwing the car about to feel it.
Darryl_1983
  RB 182 Cup
So I changed the gearbox oil on this end of January, to ensure i didn't have any future problems with it, and a couple weeks later the gearbox became noisy. So I'm currently in the process of removing the gearbox for Northcuploop to rebuild it. I did toy with the idea of having a diff fitted. But I bought a mk3 mx5 to daily instead and I've also broken that now, so that is off the road too and needs money spending on it.
So whilst removing stuff off the car to get the gearbox off, I realised there is a number of things I'd like to change in the near future.
Logged onto Kam Racing to order some gearbox oil, and a fresh clutch kit for when the gearbox is back and ended up spending over £900 on parts.
  • Godspeed G-Hook Brake Disc
  • PBS Prorace Brake Pads
  • 4 x Redline MT-90 75W90 GL-4
  • Luk Clutch Kit
  • Renault OE Auxiliary Belt Kit
  • Renault OE Water Pump
  • Renault OE Water Pump Gasket
  • Powerflex 'Road Series' bush Steering Rack
  • Powerflex Anti Roll Bar Kit (inner and outer)
  • Powerflex Front Lower Wishbone Bush
  • Grams Springs
  • Whiteline Rear Beam Bush Set
I'll update with some pictures of work in progress at some point.
Need to get some paint for tidying up the wishbones , arb and brackets, etc and a few other bits and pieces prior to putting it back together. Anyone have any recommendations for an easy to apply paint that'll actually protect these parts, stop them rusting and look good?
Darryl_1983
  RB 182 Cup
Oh and before i started pulling the gearbox of the car wouldn't start. I'd left it to sit on the drive since the gearbox went. Started it up on the drive about 2 weeks ago, and it was fine. Now i'm just getting a solid red light. So need to get that fixed too once it's back together.
MRBILLYUK
  FF Jeden Osiem Dwa
  • Luk Clutch Kit
  • Grams Springs
https://paintersworld.co.uk/2-5l-ru...PJ1BEhf1Rir8uLkc0z8LIeh2t8FNixh0aAstdEALw_wcB
Darryl_1983
  RB 182 Cup
So after getting this thing back together and replacing a bunch of parts to refresh it, I listed it up for sale after a few months for what I thought was silly money, even during the covid bomb. I think it was only listed for a few days before it's sold.
I noticed it was back up for sale last week, so jumped at the chance to buy it back. I've owned 10 182's and a 172 cup, and this has always been my favorite.
It didn't go too well though, has it as a few issues that the seller never mentioned, and broke down on the motorway 70 miles from home at 1am.
It was already the sketchiest drive of my life, as the wipers weren't working (not mentioned in the advert), and it started raining pretty heavily, not ideal driving down an unlit motorway at night.
Before breaking down it was misfiring badly, multiple lights on the dash, though some of these were already there (abs, eml, serv, tc, etc, rev back light not illuminated) and it had a code for a miss fire in cylinder 3 (though it seemed to run fine on the test drive). The speedo then stopped working and then the STOP light popped on. Luckily I managed to get onto a slip road as the motorway was unlit, and had no hard shoulder.
Turned the car off and tried to start it again, and it was dead, noticed there was a battery voltage gauge in the cigarette lighter, and it was reading 8.4 volts. So figured the alternator was dead.
Got home just after 4am after spending £300 to get it recovered.
Took a look at the car the next day after charging the battery and it appears to be the wire connector onto the alternator that has snapped. So hopefully a simple fix.
Darryl_1983
  RB 182 Cup
Manage to give the car a quick first wash before it got dark yesterday. Still cleans up ok, but I didn't think it's been polished since I last did it, so it'll be getting a full detail at some point soon.
First de modification done
Darryl_1983
  RB 182 Cup
So the previous owner has turned it into a track car, with bucket seats bolt in cage, BC coilovers with track spec spring, aircon delete, etc.
I'm going to remove a lot of this stuff and return it closer to standard. As the plan is to run this alongside my Z4, so it'll need back seats to take over duties of the Volvo. Probably not my smartest move, but I couldn't pass this one up.
If anyone is interested in any of this stuff then feel free to message me
Jamie
  Audi B8.5 RS4 & 200
What is it with sellers trying to f**k people over. Clart had a bad experience, I feel a little raw over mine, I also know another 200 owner who felt the car was misdescribed (probably more diplomatic way of putting it).
Darryl_1983
  RB 182 Cup
It's pretty frustrating, as in my case, I'd travelled 5 hours on the train (x4)/bus door to door, and it was around 10pm by the time I saw the car. The only way I'm getting home is with the car, or getting a hotel for the night and a train in the morning.
Fortunately, I didn't spend a lot of money on the car, and with the sale of the Track bits, I should be in a good position once everything is sorted.
I fixed the alternator cable using a heavy-duty ring connector. But I think the battery is dead. From memory, I bought it about 6 years ago, and given the break down I think the drain on it has killed it. So I've ordered another battery from eBay for £40 delivered.
Managed to take it out for a quick drive after charging the battery. Checked the volts at the battery, and it was 14+ once started. However, it struggled to start. After about a 15-20 minute drive, I turned it off at home, tried to restart it, and it would barely turn over.
Also, have the following codes relating to the ABS system. I did monitor the wheel speeds at each corner too, and they were a bit erratic, so I'm hoping a new battery and clearing the codes may help sort these. If not, I'll investigate the speed sensors and rings
The misfire seems to have sorted itself out, but I'll have to see how that goes once it's had a longer run. I did notice one of the fuel injectors is difference to the other 3. I definitely replaced all 4 in my previous ownership with proper Magneti Marelli items. So they were probably around 6 years old too.
Jamie
  Audi B8.5 RS4 & 200
That’s some fairly significant issues.
I always plan to visit twice - so I dont feel pressured. I know this is tough if you’re a long way away - but I did this with the S4, RS4, Williams 1 and 3. I did buy the 172, Trophy and Megane on the spot.
I came across a cat d car which wasn’t on the advert. After pointing this out the advert wasn’t updated.
If I was buying serious machinery, I’d get a manufacturer inspection. I’d happily do that for the RS4, mainly because I spend so liberally on it and it’s in great order. You wouldn’t if you were trying to pull a fast one.
Darryl_1983
  RB 182 Cup
In hindsight, I probably should have arranged to drive up and view the car, but I'd have likely still bought it if I had, as I feel like it was cheap enough. I guess time will tell. It could very well become a money pit.
I've got the new battery now, but I'll probably not fit it until the weekend, as I can't really use the car properly until I've sold my Volvo anyway.
I did however collect some new seats last night
I wanted reclining seats, so that access to the rear wasn't restricted.
The recaro seats I had previously were great, but effectively turned it into a 2 seats.
Darryl_1983
  RB 182 Cup
Spent a bit of time this weekend removing the coilovers, seats and roll cage.
Found the issue with the ABS, a broken ABS ring:
Also noticed the CV boot is starting to leak grease, I replaced this is 2021 with a stretch boot, and remember is being a nightmare. So with that in mind, I'm thinking about just purchasing a new driveshaft from eBay.
Can anyone recommend a decent cost-effective replacement? I was looking at the J&R shafts below:
I may order both sides for peace of mind, provided the above is decent, as it'll only be £120.
I'll try to get some progress pictures over the next few days, as I clean things up and refit parts.
Darryl_1983
  RB 182 Cup
I've been advised to get the original shafts rebuilt. But after I'd already ordered the above J&R shaft. So I'll fit the J&R once it comes, and keep the original in the garage as a backup.
Decided to leave the passenger side for now, to keep initial cost down. I do have a spare CV boot in the garage if I need it anyway. So could always throw this on in the future.
MAXRUNDOWN
J&R shafts do get mixed reviews. You can get CV's for the original shafts to get them rebuilt, but they're pattern parts too so no different to aftermarket shafts. The guy that advertises shaft refurbs on FB/Instagram wants £300 for a pair and you can get two sets of pattern shafts for that. I bought a pair of Shaftec shafts for my 172 cup, they're a little bit more expensive the J&R so hopefully better quality.
Darryl_1983
  RB 182 Cup
It's been fairly slow, but I have made quite a bit of progress with this.
Ordered and fitted the driver's side driveshaft, which sorted the ABS issues out. I've still got an error code of C1110, which throws up the serv and traction lights. Struggling to find the issue with this, so may end up booking it in with Diamond Motors at some point to investigate (no doubt Mick will find the issue in minutes).
Corbeau seats mounted to Jon Foz X-Low mounts. I had to order a set of Corbeau sliders directly from Corbeau, which I hadn't factored in, due to the universal sliders I already had not fitting the bolt pattern on the underside of the seat.
I have a brand new 320mm Motamec Suede steering wheel that I might swap into this at some point, as the OMP wheel is pretty old now.
Also managed to pick up a set of rear seats, seat belts, etc from a local breaker. So wet vac'ed these, and they've come out decent.
Wiper motor and linkage from a breaker has fixed the wipers, and yesterday I refitted the horn, which is now also working.
I think I managed to get a decent deal on a full set of Michelin Pilot Sport 3's at £325 fitted. So it now has brand new tyres all round. I was looking for a set of Turini's so that i could go for 16" PS5's, but nothing was available for sensible money.
Previously, I'd fitted aftermarket bushes and mounts throughout the car, but it's just too harsh and vibrates massively, so I've been removing stuff and refitting standard items. The Vibratech gearbox mount was replaced with a Meyle standard item. The PowerFlex upper engine mount insert was removed. The dogbone insert mount is still there, but the vibration improved massively, so I think I'm happy to leave this one.
At this point, the vibration mainly seemed to be coming from the exhaust at the rear. The previous owner had installed BTT polybush mounts, so I removed these and threw on a cheap OEM eBay mount, and again, that has made a big difference. But I think I still need to review the mid mounts as it's still a little harsh.
The BC Racing coilover were removed and replaced with standard cup dampers and Grams springs. I would have liked to keep the coilovers but they were track spec'ed, and the springs were too hard. If I do keep this a while longer, I may look to get a set of Bilsteins B14, or some road spec BC's.
The Corvette brake ducks and fog inserts have been removed. I have a set of fog lights to put back on the fill the holes when i get around to it.
Other than the annoying light due to the code, the only other annoying thing is that the Aircon was removed, and the delete kit causes a bit of a vibration where the tension rod mounts. I do have all the parts to put this back on the car, other than the aircon rad, so I will eventually get this refitted.
The car's been washed a few times now, but I've not managed to find the time to clay bar it and polish it up. It still looks good, but it needs a decent detail to clean it up.
