Titanium MrBlonde
Thanks,i will have to keep an eye out for a set.I guess just some vibration on idle?
There’s a little bit but it doesn’t feel like your teeth are being rattled out. On the standard 182RS seats it just felt a tad more un-refined and “90s” if that makes sense, and with my buckets it’s barely any different.
Drove the car from Bournemouth to Sheffield and back recently and didn’t feel like I was being NVH’d to death at any point, you’ll be just fine 😁
The only mount i have ever changed on the clio is the dogbone mount to the poly mount,when i got the clio.So with this in mind i was looking to freshen up the mounts and thought why not try solid mounts to go along with the dogbone mount.
So thanks to @colesy i bought a pair of mounts off Ollie.Great posting with Ollie as arrived this morning and were only sent yesterday.
Gave them a little tidy up with a coat silver paint on the upper mount and just a clean with the gearbox mount.
Interested to see how these will be on the clio,worst case i take them off and just get new febi oe ones.
I Know how to change the upper mount as i have done this before,never done the gearbox mount.
Gearbox one is easy mate, just keep digging under the battery until it's out 😂. I had such fun getting to it (that was after wrestling the ecu cover off 😂).
No problem at all, and they look great now, exactly what they needed.
Fitted the engine mounts today along with a paint of the cambelt cover mount.
Not to bad of a job,apart from trying to put the two bolts in on the gearbox mount.Do they have to go in from the bottom or can you put them in from the top then nut underneath?.
On idle it seems all fine with just a tiny bit of vibration,gear changes are more positive along with the pms shifter i have.Only thing is i have small vibration through the foot pedals,is this normal?.
Shall see how i get on with them as takes me a while to see if i will like them.
Engine bay is looking a bit more tidy now also.
So im going back to oe mounts (yes i know 😆🤦🏼‍♂️)
Ive gone for new febi mounts,but i have noticed the new febi upper mount is a bit different to the one that came off.The top metal plate that sits in the middle is bonded on and sits higher and also very tight to the sides,also the other little rubber mount is a bit bigger.I got the Febi 38825 so is this the kangoo one thats better?.
Was looking to re fit my poly mount,but seems the new mount is to tight on the sides,as it touches and bonded on.
I done the cup alternator set a while back now and had to bend one of the pipes,but ever since this i have had the main hose hang down a bit and would like to get the proper 172 cup pas high pressure hose if anyone has one please or other option is to get a company like Pirtek to copy one and have it made a bit shorter.
Pirtek in Harlow made one for me. Top service
Not sure if i still have my cup hoses but I'll have a look.
