They are available on Autodoc currently for £58 plus delivery.
Yer, plus a long wait for delivery. eBay was cheaper and got it delivered very quickly.
Did a buy from AutoDoc £66.44 delivered. Not bad to be fair, now hoping it arrives un damaged!![]()
Do these suffer with the same issues as the MK2s with the flapper box and cog that strips itself so stuck on hot?
If you had a leak that equalled hot air, would be a very obvious oily mess with dye.
The leak is very small and slow, so I don't expect that to stop the whole system from working. I think it's possibly the flap motor![]()
If the AC system is leaking there’s no way it’ll be holding at 22 bar.The leak is very small and slow, so I don't expect that to stop the whole system from working. I think it's possibly the flap motor![]()
Have you got any pictures? Where’s your ‘leak’ on the system in terms of schematically?
If it had a leak, most systems would cut out on low pressure, compressor wouldn’t turn on etc.
He's just had it filled up, if its a small leak it will hold decent pressure for quite some time. One of my cars had a small leak and the AC would work for most of summer.
@Rojer is it worth doing a fluid level check on gearbox? Looked like a fair amount of fluid and I can imagine these gearboxes are a bit fussy over levels.
As for AC - you're probably right about the flap however some cars have a coolant bypass valve for the heater, this could be the blend flap on yours? But on other cars they have a solenoid to fully bypass the hot coolant going through the cabin heater core - if thats stuck the AC won't be cooling anything.
Edit - seems your system just has a flap and an expansion valve. If the compressor is spinning, and the flap is working then I would suspect the expansion valve which is solenoid controlled.
Just had a look mate
So
3 and 5 on the screen shot are a definite no go as they are for left hand drive models.
1,2 and 4 left over and the difference between 2 and 3 is the type of gas used. If you check under your bonnet there will be a sticker and fingers crossed it's 2,to make it easier.
What I can't understand is the difference between 1 and 4 as they use the same gas and there's no obvious difference to what I can see.
Mega, and no problemThank you for checking. It would be 4 as it's the older style gas.
Just edited my post, it could be 1 or 4 but I think the only way to really find out is call Renault and see what they say.
Be surprised if a decent local hydraulic company couldn't fix or remake your damaged pipe cheaper mate.Two different Renault dealers confirmed it's the one ending in 851 and it's 211+ vat and needs to come from France.
i suggested Pirtek if they are local...Pirtek might be able to make one up.
My AC was cool for about 15 mins (including 5 mins of idling) but then went warm when I turned off the dual carriageway. Low pressure side pipe got hot where it was cool (not freezing though) when I checked during the idling time.
Sat engine off for 30 mins air cool on start up and maintained for the 10 mins drive home. Sat idling for 10 mins and air is warm.
Checked the temperature flap motor, went from full hot to full cold, does that look like it’s going full cold to you @Rojer?
A little 2 mile drive at a steady 45-50mph the temp from the vents dropped to 11.4°c (not entirely sure how accurate this device is) which was quite nice.
Stopped and idled on the drive for 3 minutes it crept up to 33°c
The cooling fan is spinning freely all the time the AC is on.
No, the flap motor stays in the cold positionYup that video shows it going to full cold. When you are at idle did you heat the flap rotate from cold to hot? If the flap was still in the cold position then something else is up like condenser/drier or lack of gas.
