They are available on Autodoc currently for £58 plus delivery.
Yer, plus a long wait for delivery. eBay was cheaper and got it delivered very quickly.
Did a buy from AutoDoc £66.44 delivered. Not bad to be fair, now hoping it arrives un damaged!![]()
Do these suffer with the same issues as the MK2s with the flapper box and cog that strips itself so stuck on hot?
If you had a leak that equalled hot air, would be a very obvious oily mess with dye.
The leak is very small and slow, so I don't expect that to stop the whole system from working. I think it's possibly the flap motor![]()
If the AC system is leaking there’s no way it’ll be holding at 22 bar.The leak is very small and slow, so I don't expect that to stop the whole system from working. I think it's possibly the flap motor![]()
Have you got any pictures? Where’s your ‘leak’ on the system in terms of schematically?
If it had a leak, most systems would cut out on low pressure, compressor wouldn’t turn on etc.
He's just had it filled up, if its a small leak it will hold decent pressure for quite some time. One of my cars had a small leak and the AC would work for most of summer.
@Rojer is it worth doing a fluid level check on gearbox? Looked like a fair amount of fluid and I can imagine these gearboxes are a bit fussy over levels.
As for AC - you're probably right about the flap however some cars have a coolant bypass valve for the heater, this could be the blend flap on yours? But on other cars they have a solenoid to fully bypass the hot coolant going through the cabin heater core - if thats stuck the AC won't be cooling anything.
Edit - seems your system just has a flap and an expansion valve. If the compressor is spinning, and the flap is working then I would suspect the expansion valve which is solenoid controlled.
Just had a look mate
So
3 and 5 on the screen shot are a definite no go as they are for left hand drive models.
1,2 and 4 left over and the difference between 2 and 3 is the type of gas used. If you check under your bonnet there will be a sticker and fingers crossed it's 2,to make it easier.
What I can't understand is the difference between 1 and 4 as they use the same gas and there's no obvious difference to what I can see.
Mega, and no problemThank you for checking. It would be 4 as it's the older style gas.
Just edited my post, it could be 1 or 4 but I think the only way to really find out is call Renault and see what they say.
Be surprised if a decent local hydraulic company couldn't fix or remake your damaged pipe cheaper mate.Two different Renault dealers confirmed it's the one ending in 851 and it's 211+ vat and needs to come from France.
i suggested Pirtek if they are local...Pirtek might be able to make one up.
