BG 182 cheap runabout.
Bowz
Bit of a read, grab a brew or a beer.
For a little while the missus and I have wanted a cheap runabout for the school run, shops and on the days I travel to the office I park at the local train station. We have both have our own daily cars but they don't warm up on those journeys, so we agreed a 3rd car (4th including my 172 Cup) would be a half decent idea. 1st world problems.
We looked at Clio Campuses but they were all pretty rough and the wife said "I like the Clio's with two exhaust tips"..... "you mean a Clio 182?"....
Licking my lips, I ran to all the usual places and of course, FB Market place came up with the goods.
One from the 10min test drive.
And on my drive with the missus looking happy because it has two exhausts.
Black Gold, both Cup Packs, 122k Miles, no history and a crunch in to 3rd gear. Serv, ABS and Engine light on.
Noice.
It gets better. Kind of.
It was off the road for 6 years. The guy I bought it from had ideas of a track car but was up to his eyes with MX5 time attack cars, which meant the Clio took a back seat.
Taking in to account the issues with it, I made an offer and drove off in to the sunset.
First impressions, it's very comfortable, it's RAPID.
Doing my own sleuthing I was able to find it had an owner who was on here and I found the owner before him who was super helpful and provided me with some of the history from 2017, almost ten years ago, but still.
Got it home and made a to do list.
Gearbox - it really is that bad going in to 3rd, fear not @NorthloopCup is on the case.
Service - Oil and filter, cabin filter and put a standard airbox on it.
Tyres - current tyres are 10 years old and cracking.
Belts and dephaser - soon.
Brakes - more on that.
So when I stuck my head under the car on inspection purchase I noticed the rear passenger caliper had one very shiney bolt but thought nothing of it. When I got it home I jacked it up and decided to have a poke around. Gave it a scan with RS Tuner = Rear ABS sensor. Fine.
Cool. I'll do rear discs and pads with an ABS sensor.
Remember that rear caliper with the shiney bolt? Yeah, it was GLUED on. The head of the bolt was GLUED on.
WTAF. Anyway, moving on. It gets worse before it gets better.
I spoke to one of those FB Clio breakers and asked for a rear passenger caliper. And I got this.
Mistakes happen. Fine. I was asked to post it back and the correct one would be sent out to me. Posted back, at my cost (no offer of a refund to cover their mistake) and then I recieved this.
Yes. That's a snapped bleed nipple.
At this point I gave up and ordered a reproduction caliper from Ebay. Bigistake.
I fitted this caliper (I've fitted many a rear caliper), new rear disc, new pads and retaining clips etc and I went for a drive. I got no more than 2 miles from my house, bedding the new discs and pads...when I hear an almighty bang. I thought it was a blow out and then I thought a piston had ejected from the block. Alright, I'll come to a stop. I said I'll come to a stop..... NO BRAKES.
Managed to get home engine braking.
Took a look at the caliper and.....
FFS. No idea. It also snapped the brand f**king new disc and damaged the wheel cosmetically.
I was pissed off and I left it on axle stands on my drive much to my neighbours delight for a month.
Eventually I sourced a genuine second hand caliper without a snapped bleed nipple. Fitted it, bled the brakes and that was that drama over.
Now that was over, I thought I'd do some far easier jobs...he says.
Binned the black side repeaters
Cabin filter... This looked promising.
Yikes.
Fresh one in.
The updates you come to this forum for, I know.
Then I did a bit of this.
And treated some of those usual areas.
Then I changed the coolant and coolant bottle.
Big first post for this procject but there's more to come.....
I had some almost brand new injectors laying around from my 172 Cup before going 197 injectors, so I dropped them in.
I also fitted new front brembo HC discs and pads.
And after all that it's been a right blast.
Still needs a gearbox and tyres, but honestly, it's a really bloody good Clio.
The thing which it's making this Clio stand out is how bloody fast it is. I know it has a 98RON map from RS Tuner and a catback but it's quite quick.
Love this. I’d like something like this as a runabout, but parts are getting quite thin on the ground now.
Looks the business dude! Good seeing you back in another 182 :)
Also nice seeing you active on a thread with your level of attention to detail. Can still feel that you did a good job when you owned my one lol
Looks good for a runabout! What's the ramp/stand that you have them on? Look useful and maybe easier to use on the driveway? I will have to start a build thread at some point myself!
My fist cs was a BG 182 at 18 I remember creaming every time “vtec” kicked in what a time 😂😂😂
Yours look a sweet one for a run about btw 👌🏿
It's a Quick Jack. So much easier and safer than axle stands.
Progress.
Absolute paramount was seeing if I could get the AC working. I booked it in at FitKwik, yes. Well, they are so close to me and they offer a "free test of the system before regassing", which given it's a 20 year old Clio, I couldn't refuse that free test.
Good news, there's no leaks. So the system was regasssed and the AC blows icecold.
Next, oil and oil filter.
Oil that came out wasn't bad, had hints of brown colour to it still. Which was nice.
Dropped in some Fuchs Titan 5w40
OEM filter.
Lubed the rim.
Spark plugs. I don't know when these were last changed and they're fairly cheap so fitted some new NGKs.
Cylinder 1 (driver side?) has a mild oil leak in the cylinder, which could be coming from the VVT solenoid, or could be a rocker cover.
Fresh ones in.
Bleeding the brakes, again. After the initial brake issues I had bled the brakes but I knew it needed doing again.
Having done this once, not long ago I spotted this.
Doesn't look it, but it's round.
So I ordered a replacement.
Lastly, I've been invited to an event at caffeine and machine this weekend, which didn't leave me with much time or funds (most are going towards the 172 Cup rebuild) to order new tyres, so I fitted my 2118s.
To do:
Gearbox, Clutch, Clutch Cable. Crunch in to 3rd can be avoided if you don't rush it.
Belts and dephaser. Job for winter.
Tyres for the Turinis, the 2118 are temporary.
Suspension and bushes refresh.
Yeah, originally I didn't use the open end but this was the second rodeo and I knew it was a shape science hasn't named yet, so placed the open end on it to see how bad it was. In the end I used a smaller sized socket.
I googled the cylinder order as I knew/thought I was wrong. Turns out Google is wrong too 😅
