What's the fault code it's giving you?
That code suggests the second sensor to me. It is saying the cat isn't working as well as it should be.
A cheap fix for now would be to fit an angled spacer to the sensor.
That doesn't fix the cat being past its best (which will probably get picked up on its next MOT) but it will get rid of the fault.
If you want me to take the key apart and reflow the board let me knowI was recruited to taxi my daughter about on Friday and the car was making a clunking noise again. One part of it was tracked down to the drivers seat so I'll have to remove that and have a look to see if anything is loose. More clunking was happening though so back up in the air for a spanner check after having a quick look areond it and the drivers wheel again seeming to be a bit far forward. View attachment 1785856
Assume favourite position. View attachment 1785859
Full spanner check done and nothing loose so dropped it back down and still clunking when steering so I sprayed some lube on the steering column uj and clunk gone. Wtf? That is very frustrating.
Even more frustrating is that later that day the car decided it doesn't like the keycard anymore and won't talk to it.
So here we go again using the key in the passenger side door lock to get in the bloody thing. Last time I sent the keycard off to someone on ebay to be repaired and I might do that again but first I think I'm going to bite the bullet and get a new one supplies and programmed by Renault. There's a Renault dealer over the road from work, unfortunately it's a Stoneacre who are on my s**t list due to an bad experience I had with a seat ibiza I bought from them ages ago so I might just look elsewhere. Obviously now I've to piss about to get in the thing rain is forecast later this week.
I'm off to Newby Hall on Sunday for cars in the park, in the M2, again.
Do wot now?If you want me to take the key apart and reflow the board let me know
I will take the board and reflow it so re-wet all the components.Do wot now?
Do wot now?
Oh, like you did on your clio's engine?He’s gonna take your board and spunk on it Paul, that’s what he means the mucky man
I used it for a year or so after I sent the key away for repair but it always asked for a new battery. It's relegated to emergency use only now and I might even get another one in a month or two so I have two working keys.How many ignition cycles has it had since the key battery was done?
I know it takes a few before it registers sometimes. I think you can press the unlock button like 6 times to force reset it.
Wheels look great. Where did you get them from?
Headlights also look good
Thanks, Kyle bought them for me years agoWheels look great. Where did you get them from?
Dunno I've never been. Probably won't be worth going twice.C&M is quite local to me, but I’ve never been lol! Is it normally attended by try hards? Or is the majority sensible people?
