Clio 1.8 16v - "barn" find
Here goes nothing :ROFLMAO:
It’s been sitting in a forest in pretty much the same spot for seven years, and for the last three, I’ve been trying to convince the guy to sell it to me...
Well, today was the day.
So, here it is in all its glory: a 1991 Clio 1.8 16v (Phase 1 Diac), cat-less version, rotten as can be, but with paperwork and nearly complete.
The plan is to first give the car a thorough inspection—inside and out—to see exactly what’s there and what’s missing. I believe it was last registered back in 2013.
It is the Diac version, though it has different seats.
Anyway, it’s ideal as a donor car for parts—or for transferring everything to another chassis for homologation—but we’ll see how it goes.
If this car could talk, I bet it would have quite a story to tell...
What puzzled me was that the car is grey, yet the engine bay and the entire interior are pearl white... I didn't get any answers from the owner, nor any photos of the car from the past, and I kept thinking it was a shame—I’d really love to know what the car used to look like...
So, I kept tirelessly Googling, trying to find old listings for Clio 1.8 16v models, and this one thread kept popping up: (Croatian Renault forum, thread for all clio 16v and williams in Croatia)
I hadn't opened it because I thought, "Nah, there's no chance it's in there..."
Just as I was about to give up on the search, I clicked on the thread, started scrolling through, and couldn't believe what I saw:
THE CLIO WAS IN THAT THREAD 😵 What are the odds... Two (or three) specific details match up, confirming that this is indeed the very same Clio:
The TSW Wheels sticker on the rear side window, the Williams sticker on the trunk trim, and, of course, the pearl white paint...
Unfortunately, there aren't many further details, other than a post by one forum member saying he knew the guy and had posted the ad for him; however, that member hasn't been active on the forum for a long time, so I doubt I'll get any more info from him...
What a car, what a story... truly. I took a closer look at everything today, and I’d say the car was professionally painted pearl white; someone really put in the effort, since the engine bay and the cabin were painted too...
I don't know how it ended up in its current grey color, but it was done poorly..
What a shame—things deteriorate so easily when they aren't taken care of...
Anyway, today I took out all the stuff that came with the car; I wouldn't exactly call it useful, but oh well... What the car is missing is the intake manifold and the VIN plate from the radiator support... I asked the previous owner, and he said he found that odd and would look for them again...
And yeah, the engine wiring harness has been cut in two places, and—of course—the cut-off sections are nowhere to be found... just great...
The car had been sitting at a friend of the owner's place, and all sorts of things happened there; who knows what went down, but the fact remains that a few—let's call them essential—parts are missing... hopefully, they'll turn up...
Since the car has been without an intake manifold for quite a while, the intake ports were in a bit of a state (see photos below), so I gave them a quick blow-out with the compressor and sprayed them with a mixture of ATF and acetone—I did the same for the cylinders after removing the spark plugs...
The engine turns over. It was a bit reluctant to start moving at first, but now it spins freely; I suspect the alternator seized a bit. I even managed to get it to crank, but it seems like the starter motor is on its last legs; it turns slowly and needs a tap just to get spinning...
I took a look underneath, too—the condition is bad, but realistically, what could one expect...
The engine and gearbox appear to be the originals for the Phase 1 model: F7P 700 and JB3 048.
I was actually surprised that the front sections of the rocker panels are relatively solid; I was able to jack the car up without any issues.
What next? wait for the owner to try and dig out the intake manifold & get a hold of engine harness.. And need to find a solid shell to part out for healthy metal for this rust bucket..
Good thing bordanova sport has replica rear quarters. I think the car is originally white, and thats quite rare here in Crotia, but since the car doesent have a plate underneath the hood, cant know how to check it..
Plan is, after all the metal work is done, to have a wide front track conversion, and tune up the F7P a bit, but long way to go still..
Cheers!
That's a huge project you've taken on, good luck. It'll be a toss up between repairing the shell or getting a better shell to put the bits on. If you get a good shell that is easier to paint that may tip the balance.
Yea.. clio 16v are getting raaare in Croatia, very rare.. almost none on the streets anymore..
I dreamed about clio 16v for years after my brother bought one and drove me in it.. the intake sound, the interior, the exterior.. its nuts.. in my opinion better than 1x2, regarding the experience.
But since that was long time ago, I am thinking about sorting a test drive in a 16v to see if its just a memory or if the car is gonna give me the "chills" and motivation to throw money into building my own.
The VIN is also stamped onto the suspension tower on the passenger side of the engine bay and I'm fairly sure the colour code for the paint is part of that number
As for the metal repairs, sills are still widely available, the jacking points are as well but I only know of the ones available in the UK and obviously Bordanova for the rear quarters.
The inner sill structures will be the biggest issue with the repairs, you can use Renault 5 GTT repair parts which are available in a few places but it depends how deep the rust goes.
As an FYI, if you remove the outer skin of the rear quarters, the structure in there is exactly the same as all of the 3 door Mk1 Clio's so you don't specifically need a 16v shell as a donor
Quite by chance, I ran into the person who owned the car before it was painted pearlescent. I reached out to him regarding some bodywork, sent a few photos, and the guy says, "That was my car!" – can you believe it? 🤣
He bought it (from Rijeka/Bakar) about 20 years ago. He mentioned that the car wasn't in great shape back then, though it was fast and had around 200,000 km on the clock. Eventually, it ended up with the guy who gave it that pearlescent paint job.
Now, since forum member on Croatian forum claims the car was in top condition, either the guy who did the pearlescent paint job invested a huge amount of work into it, or these are actually two different cars.
The good news is that the previous owner found an intake manifold, so I need to pick that up. However, I’m still left with a cut-up engine wiring harness..
Guys watching this thread that have experience in valvers
Is the front subframe specific to the valver, or is it same as 1.4S front subframe? (Generic clio 1 front subframe)
Is there any point in strenghtening the front subframe (like stitch welding)?
I am thinking about wide front track and I know the popular option is clio 1x2 and clio willy/r19 16v ARB, but megane F7R has the same arb and wishbones, so I will be using that, and need hopefully jc5 and f7r driveshafts. Any other tips?
are the top mounts same as clio 1x2?
Can the pms strut brace with solid top mounts from clio 1x2 be used on a valver?
@16v_paddy @Brigsy @16V F7R @Coops Mk1
The front subframe is exactly the same on all Mk1 Clio's, it's only the williams that is slightly different with some extra bits welded onto it, as for stitch welding it, if you can do it yourself I suppose it can't hurt but I haven't bothered to do it on mine as I can't weld and can't be bothered to spend money on that
PMS do a strut brace for the 16v/Williams, the 1*2 one doesn't fit as the strut towers are further apart (27mm iirc) on the Mk2
There's a few different ways you can do the widetrack, the common one people do is the 1*2 stuff as it's all readily available over here. The ARB & wishbones are easy, it's the shock absorbers, stub axles, hubs & driveshafts that you need to pay attention to and have the right combination of bits depending on what shocks and/or driveshafts you use. You have to use either Williams or Ph1 172 shafts as they're the only ones that are the correct length to work in a Mk1 and you also have to have the matching hub drive flange pressed into the stub axle as the CV joint splines are different sizes
I agree. Heck of a project. Love the optimism and I’m sure the journey will be epic. I can see a re-shell coming! Good luck with it and looking forward to updates.
Time for an update.
The previous owner found an intake manifold and also gifted me a set of adjustable Koni rear shock absorbers (the yellow ones).
The intake manifold is complete but extremely dirty. The wires to the TPS (throttle position sensor) have snapped off; apparently, this is a common issue, and a new TPS costs around €200...
He also gave me the connector, so at least it’s all there—though the wires broke off right at the point where they enter the plastic housing, which makes soldering them quite tricky.
I took the TPS apart—the plastic was brittle and cracked, as expected—but I managed to expose enough of the wires to attempt a solder job.
The wires on the connector aren't original; they’re silver-colored and wouldn't take the solder at all. Still, I managed to get them joined somehow—we’ll see if it actually works.
I’ve cleaned the outside of the intake manifold and the throttle body, but the inside still needs a good wash.
A broken-off section where a bracket should attach.
It’s filthy inside—basically a thick layer of oil sludge and carbon deposits.
My guess is that the engine was pushing a lot of oil through the breather system (crankcase ventilation), which caused all this buildup.
I found an engine wiring harness in Italy for a decent price—it’s in good condition—so I compared it to mine to confirm that mine is indeed a "Phase 1" version and to see exactly what had been cut or removed from my original harness.
In the process, I discovered that the car was originally white, which is quite rare. engine bay
Basically, here is what I found cut:
4 wires leading to/from the ignition coil
3 wires leading to/from the fuel rail wiring harness
A bundle of wires leading to/from the fuel rail/thermostat harness, etc.
2 wires from the crankshaft sensor
My initial assumption was that someone had cut these wires and taken parts—given where the car was parked, that wouldn't have been surprising...
Almost all the connectors were unplugged, so I started identifying each one, plugging them back in, and essentially "tracing" the wiring harness.
To my (un)pleasant surprise, it turned out the harness wasn't cut for the sake of theft; I managed to locate the other ends of almost all the cut wires. This suggests someone did it intentionally—to prevent the car from starting... unbelievable...
I’ve found the connections for everything except for 3 wires coming from the fuel rail harness; also, the 2 wires leading to/from the crankshaft sensor don't quite make sense to me yet.
Well, at least I have practically everything there; I just need to figure out where each wire goes and solder everything back together.
That’s exactly what I’ll do once I get a replacement wiring harness.
Last time, I used a bad battery, which made the engine crank very sluggishly. This time, I used a jump starter (booster pack) and—while I was at it—tightened the positive terminal clamp, which had been left unscrewed. To my surprise, the engine cranks over very briskly, which means the starter motor is in good working order. (This was, of course, with the spark plugs removed.) And when I took into account that the installation was cut, it made sense to me that there is no communication with the ECU and the rest (fuel pump, etc.). Although the pump is most likely broken from standing still.
Here's a video of cranking
That's it for now, we'll see little by little.. I found the pump in Italy, the main one and the auxiliary one.. Italy is the main source for parts, they sell a lot of things there.
You want to talk to this guy on Facebook, he repairs & refurbishes the TPS plus a lot of other bits as unless you've discovered a hidden goldmine over there, the throttle sensors have been unavailable for a long time
He does sell a lot to the continent so it's not as much of an issue as you might think ;)
Helloo,lLets write an update
I took the injectors from the Clio to be cleaned; 3 out of 4 were fine, but one was completely dead. The 5th injector—the one used for cold starts—couldn't be revived either.
I remembered that I had bought a fuel rail from an R19 16v for my Mégane, and fortunately, it still had its R19 injectors attached. They’re a different color, but the specifications are identical. I had those cleaned as well, and after quite a few attempts, they were all successfully brought back to life. However, since the R19 rail is physically different, I transferred everything over to the Clio’s rail. I ended up using 3 injectors from the Clio and 1 from the R19—mainly because the plastic atomizing tips on the R19 injectors were in poor condition.
I tried connecting the fuel pump directly to 12V, but it showed no signs of life. I tapped on it to see if it would wake up—and it actually activated, emitted a faint buzzing sound for a few seconds, and then died completely. I checked some auto parts catalogs to see if pumps were available, but then I remembered I had a pump from a Mégane I 1.6 16V. I retrofitted it into the Clio’s pump housing, and it works now. I just need to come up with some kind of filter—a strainer, really—for the pump inlet, since there’s a lot of debris in the fuel tank (likely left behind when the pump was removed previously, or something along those lines).
The fuel lines appear to be disconnected and in bad shape, so I bought about 8–9 meters of new fuel hose to replace everything. This way, I can be sure it’s secure and won’t leak—though I haven’t gotten around to that part of the job yet.
Given that the engine harness was cut in several places, it was not the easiest to determine where to solder what (especially the bundle of wires). In Italy I found a man who sells the harness and a few other things for a really reasonable price and I really have words of praise for that seller, he also gave me the entire installation that goes for the headlights, fog lights, etc.
So, I bought: clutch as new used for a few hundred km, front and rear mask ph1, and he gave me 2 relay covers from phase 1 as the car has ph2 cover.I thought I would compare my installation with the new one and solder all the wires that were cut, but I didn't have the patience for that because I wanted to put the installation on the car as soon as possible and try to start it
Cleaned the intake as much as I could, it was really horrible, it's better, but it can be even better.. good for now, and bought a new intake air temp sensor since the old one was broken.
I removed the hood from the car to get better access to everything. First, I took out the old wiring, then I started cleaning the intake ports—they looked absolutely terrible... I used a brush attachment on a drill, along with WD-40 and brake cleaner, and now it looks significantly better...
After all that, I sprayed down the entire intake ports and poured a mixture of ATF and acetone into the cylinders (again) to help lubricate everything.I cleaned the connectors on the new wiring harness and all the sensors using contact cleaner, then hooked everything up. It took a bit of head-scratching, but since there aren't that many connections, I managed to get it done—though not entirely; I have a few leftover connectors and can't figure out where they’re supposed to go... we’ll see! 🤣
I bought an intake manifold gasket, but—naturally—it turned out to be for a 16-valve Mégane, not a Clio. So, I just reused the gasket that was already on the cylinder head, adding a bit of silicone where it had started to peel away to ensure a good seal. In any case, this is all just a test to see if the engine is even alive; I can always sort everything out properly later.Installed the throttle body onto the intake. ...and the idle air control valve, and tried fitting it onto the car—but it just wouldn't go on, no matter what. The power steering pump was getting in the way, preventing the intake manifold from seating properly, so I did a bit of grinding on both the intake and the pump—literally just 1 mm—and it fit like a glove.
Everything on that engine is such a tight fit that I don’t know how I’d manage to do any work if the radiator, core support, and other parts were in place... there’s literally not a hair’s of space to spare.The exhaust was already unbolted; I took it off, cleaned the flange, and put it back on—now I just need to connect it to the rest of the exhaust system.
I screwed everything back into place and pulled out the spark plugs to check for a spark while cranking. I didn't have much faith in the ignition coil, bu behold—a spark appeared, just as if the car were being driven regularly! I put the spark plugs and ignition wires back, sprayed some brake cleaner into the intake, cranked it, and the car started literally instantly—I couldn't believe it...I tried it about 5 or 6 times, and it started every single time; it’s showing signs of life—it wants to run!
There’s no exhaust system, which explains why it sounds the way it does.
And that’s it for now.
Next, I need to connect the exhaust so the car isn't quite so loud when it starts, and I have to run new fuel lines. I also need to check if the fuel pump gets 12V once everything is connected to the original wiring... I’m hoping to get that done this week.
time for an update!
Given that the clio has a 5th injector that works on cold start, and as the existing one on the car could not be revived, the output on the rail had to be threaded.
The thread is quite unusual, m8x1, I didn't have such a screw, so I threaded the whole to m8x1.25.
Pulled out the fuel pump housing to insert a mesh filter under the pump suction, so that it doesn't pull something from the reservoir, since it's not very clean..
ran new fuel hoses for supply and return, as well as a new fuel filter... The existing hoses (what was left) were destroyed, up to the front beam, where the rubber hoses go to the rail.. I left that part because they seem ok, for now
I didn't trim the hoses to the required length because the plastic underbody panels—where the hoses are usually routed—are missing, and there’s nothing to secure them to. So, I just left them coiled up underneath; the car won't be moving for the time being anyway. Once it’s ready to be moved, I’ll trim them and find a way to secure them.
The intake manifold is from a PH2, as is the throttle body. The intake manifold has a different layout for its vacuum outlets, and the throttle body lacks a mounting point for a specific sensor (I assume it’s the temperature sensor that triggers the 5th injector).
Also, the MAP sensor port is located on the passenger side of the intake manifold, near the timing belt end; however, that nipple is broken, making it impossible to connect the MAP sensor there.
The Phase 1 (ph1) manifold has two outlets in that area, while the Phase 2 (ph2) manifold has an extra outlet at the "top" of the intake.Here is a video of the car starting up on its own fuel; my brother had to keep the vacuum ports plugged so the RPMs wouldn't climb too high.
The exhaust manifold was bolted on, but not properly, so it still sounds like an open exhaust manifold. It was also running on only 3 cylinders—the first cylinder wasn't firing. A quick adjustment—pulling the spark plug wire out slightly—was enough to get a "stronger" spark and get it firing again.
It wasn't recorded, but I did push it a bit to see how it would behave; however, it would choke at full throttle—though that’s no surprise, considering the MAP sensor wasn't connected and the TPS wires had broken off.
Still, there were no strange noises...
A few days later, I started sorting out some minor details.Hoses were missing for the crankcase breather connection to the intake and for the MAP sensor. I ended up using the extra vacuum port found on the Phase 2 (Ph2) on top of intake manifold to connect the MAP sensor, while the broken-off side port was sealed off to prevent it from pulling air. The MAP sensor hose is 5mm.
As for the hose running from the valve cover to the intake manifold—it’s 10mm at the valve cover end and 8mm at the intake end—so I bought an 8mm plastic hose, heated it up a bit, and managed to stretch it onto the valve cover fitting. It actually looks pretty cool in green! :D
I bolted on the 2-to-1 exhaust manifold and connected it to the rest of the exhaust system. The exhaust is shot, so it leaks a bit, but it’s still better than having an open manifold. I spent about an hour wrestling with it to get the manifold positioned just right.
Since the wires on the TPS connector were some kind of silvery metal that wouldn't take solder, I soldered standard copper wires onto the TPS itself and then connected those using crimp terminals—that should be a lot better.
Started the car, it worked better, gave it a little throttle, it responded good, it didn't choke with everything connected, and what surprised me was that everything works from those sensors..
Everything in the cabin doesn't really work, the instrument panel has a little of its own will, the ventilation, wipers, etc. don't work, it's possible that it's either disconnected, or the masses are bad or everything has simply corroded over time, so everything needs to be cleaned a bit, but the lighting works normally when the lever is turned to the position, although when you turn to low beams, everything goes off... that will be checked when the mechanics are sorted out.
Since it was working well, I wanted to let it work longer, but there was no radiator or water, so I looked at it a bit. The radiator came with the car, but disconnected.I looked to see if all the hoses were in place, and they were, although there were leaves in them from standing, as well as in the radiator, but nothing that couldn't be dealt with.Tried the fan with 12v, and it spun happily..
I put the radiator in the car, rinsed it a little so that something would come out if needed, and connected everything back.. what I found out is that the sensor on the killer is at fault, i.e. it has a different connector, because I can't connect the jack from the installation to it, I have to get a new one. I assume it's the "switch" to turn on the fan.
And then started it again
I also wanted to remove the thermostat, but I really didnt want to deal with it, because i wanted to see how it would perform, so I skipped that part.It works very well, although at slightly higher revs, either the idler is bad or it's drawing fake air somewhere, but when I dampen the suction from the idler, it calms down nicely.
And the most important thing is that it receives the throttle well, there are no sounds from the engine... at least the little that I heard, because it was already almost 10 pm, so I didn't really want to press it too much.
And that's it for now, it's honestly unbelievable to me that after so many years of standing, in the humidity and everything, the sensors are still working, the car literally wants to go back into life.Even the alternator is charging, it's unbelievable.. at the beginning the light blinked and then it went off after a while when the car was running.. the multimeter says it's charging 13.6V, and the oil light goes out very quickly.
So the car has old spark plugs, it has old oil that is still contaminated with ATF from flushing the cylinders.. I didn't even check the gearbox..
Next plan is to measure the compression to see the health of the engine, although I would like to let it run for a while first, so that everything gets a little warm and warms up as it should, and if it shows good results, then it will continue with the oil change and also measure the oil pressure, new spark plugs, etc., etc.
The more I work on the car, literally everything just keeps going in the right direction, and the satisfaction is huge.
Cheers!
helloo
The plan was to check the compression on Wednesday. However, it’s been raining in for the past week—like it’s never rained before—so that didn't happen. I barely made it through the day without going to check on the Clio; I was just eager to know! :D
It was raining again on Thursday, and the weather was miserable, but I decided to get it done—even if I ended up soaked from head to toe. A little rain wasn't going to stop me! I swiped my wife’s pink raincoat and off I went. :D
Anyway, here’s how it looked... where there’s a will, there’s a way! (If only I had this much motivation to finish CS169...)
After removing the spark plugs, I used a flashlight to check the cylinders for any signs of water—in case the head gasket had blown or something similar—but everything was completely dry. I didn't really expect the engine to be in good health—that is, I didn't expect good compression results...
When I started with the first cylinder, it showed 12 bar; I thought, "Alright, this one's good—the others will probably be worse."
Once I’d measured everything, I was—honestly—shocked by the compression...
I was overjoyed that the engine was healthy; it meant I could continue with its "revival."
I checked the coolant—it was still in the system, so none had been lost. I wiped the spark plugs clean (they were covered in oil, as the valve cover is leaking), screwed them back in, and started the car to see how it would behave with the coolant—checking for leaks and whether the thermostat would open. Against all odds—considering the car had been sitting for ages with the hoses disconnected and no coolant—the thermostat actually opened (it works!), the temperature gauge is functional, and there are no coolant leaks. I couldn't believe it!
I got the cooling fan running by jumping the connector for the thermal switch with a wire. It seems to spin a bit weakly or slowly, though I’m not entirely sure how fast it’s *supposed* to spin... regardless, it held the temperature just fine.
The idle RPM is also a bit lower than last time—maybe it’ll settle in even more over time.
I let it run for a while to get everything warmed up.
I had to give it a little rev to see how it breathes! :D
This video was taken once it was fully warmed up, and it’s running nicely. It did struggle a bit when it was cold, but that could be down to anything—plus, it was extremely damp outside, and moisture has a way of getting everywhere...
Anyway, I’m absolutely thrilled! Now I can continue with the engine refresh. I also need to check the transmission and get the front brakes working—right now, there’s basically nothing there...
Stay tuned!
