my lil 1.2 16v Dynamique on a (54)
totally standard ( no A/c) i got windows
(no electric sun roof, just a pop-up one):
16valves sound slightly noisier than 8 when cold, but after a mile it's up to almost running temp, & nice n' quiet.
out runs standard 1.2 75 bhp Punto's * we seem to have a lot of them around here* just handles a little bit better on the "B" roads
able to hit the Rev limiter in 1,2,3,4 gears but not 5th ( the road never seems long enough)
Overtaking: ok can be a bit nasty, but my personal advice is, dont do it unless you have room * dont argue with anything made from more metal than you are, 3rd gear will crank you up to 80 before you hit the limiter & if you need to slow down in a hurry,3rd will bring you down from 80 also, without the engine sounding horrid or over rev'ed also without your front end giving you a nudge, also stay on 4th as long as you can especially when arguing with something weighin 40ton's, 30feet long & trying to keep you from over taking.
Treat the throttle gently ( not an on / off button)
Momentum!, Momentum!, smooth Momentum!. & about 3600 rpm is a sweet point to be.
MPG wise for mine:
50/52 Mpg, driving @ 55Mph on average.
47/49 Mpg driving @ 60-70Mph on a run
44/46 Mpg driving @ 90Mph over an 8ml clear section while going to work.
37Mpg on average in town & waiting in traffic using 1st 2nd & 3rd gears mostly.
does return about 52+ mpg @ a steady 45mph in 5th gear.
with driving to work etc it returns about 530mls to a tank on average give or take a little.
runs good on either 95 octane or 98, peeps check ya filler caps it runs sweet on both. but i mostly put 1 tank of VP in for every 3 tanks of standard 95 oct fuel.
all in all, its small, cost new 9000 compaired with a Fiat pug 1.2 which at the time was about 7500. a Fiesta or Corsa are cheaper.
errrhm Why did i buy one!
couldnt afford a Cup @ the time, & driving 50 mls a day to work N' back the MPG's played a small role, & I like to be different & didnt want dci.
It has an hmm understated style about it which puts a confused expression on some peoples faces, so can ya fault the little puddle jumper, nah, its all good & a lot of fun.
just wish all that plastic was a little more ehm arh whats the word Arh ! "quiet".
